Old 10-23-2012, 05:43 PM   #1
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Leaking propane?
Someone here in our campground is leaking, and with the winds, no one can be sure who's coach it is. I had heard of a "sniffer" that will detect leaks, anyone have one, or know where to get one?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-23-2012, 05:51 PM   #2
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Mike, try a HVAC outfit to see if they have one. It may cost to have them come out.
Or, try Lowe's or Home Depot (call first) and somewhere with plumbing and heating supplies.
Or, have everyone turn off their propane at the tanks and see it if stops, then turn each on, one by one and use your nose and then soapy water.
It could be the campground propane station or natural gas lines in the area—they use the same odorant.
Gene
Old 10-23-2012, 05:56 PM   #3
Mike Leary's Avatar
Images: 11
Thanks, Gene. Are you on the road heading for the "green & grey"?
Old 10-23-2012, 06:29 PM   #4
Master of Universe
Gene's Avatar
I guess you mean the northwest. We leave Friday. We'll be on infamous I-5 in Washington from Vancouver to Tacoma—hope we don't have the crazy time you had.
Gene
Old 10-23-2012, 06:41 PM   #5
Mike Leary's Avatar
Images: 11
Gene
I hope no one has our experience! Are you doing I-84 to Portland? If you're going to do the "loop", why not cut off at Olympia and go up Hood Canal on 101? Best oysters in the world. Happy trails, keep in touch.
Old 10-23-2012, 07:24 PM   #6
Master of Universe
Gene's Avatar
Did you find the propane leak yet?
Gene
Old 10-23-2012, 07:57 PM   #7
Mike Leary's Avatar
Images: 11
Gene
I'm going for a stroll with a lit cigarette to see what blows up. It is such a on-off smell, that it's impossible to track right now. The office knows about it, but what can they do? We've got 100 coaches here tonight.
Old 10-24-2012, 06:42 AM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The mercaptans added to propane and natural gas to provide the sufurous "rotten egg" or "rotten cabbage" smell aren't necessarily the only source of the odor. Stagnant water— especially stagnant black water— can sometimes give off the same miasma.
If the campground sewer hookups or dump station discharge into a vented septic system rather than into a municipal sewer line, you could be smelling the septic tank vent.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-24-2012, 09:22 AM   #9
1981 31' Excella II
New Market , Alabama
Yeah it could be sewer gas if it is hot out especially. Burnt propane smells as well. That smell does not go away just because it went through a flame. An advantage of having a real float gage on your tanks is you can tell if you are loosing a lot of propane. I found a leak at home that way. Nothing was running but the tank level kept dropping. Soap and water works well for detecting leaks.
Perry
