Old 12-24-2007, 10:02 AM   #1
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Kit to use Trailer Propane for lantern/grill
Can anybody point me to a kit / part that would allow me to put attache a LP hose to my trailer propane hookup that I could then use to power an outside lantern or grill? I don't want to pack additional propane tanks.
Much thanks!
sigv is offline   Reply With Quote
Old 12-24-2007, 10:11 AM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
I dont know about a special kit, but I did modify my system to accomodate a gas grill. I removed the elbow where the gas line headed back from the tanks to the coach and replaced it with a tee and a gas valve. When not in use the valve is "off" and a cap installed on the output. To use it I remove the cap and attach a hose with a matching fitting. Remember that the gas is already regulated so you don't need a regulator at your BBQ.
My feeling is that a kit for something simple and straight forward like this would fall into the category of instructions (with pictures) for using a pencil sharpener.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 12-24-2007, 10:14 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I did a similar thing. I attached a hose with a quick connect and a shut off just past the regulator. I store the hose in the tank cover.
Old 12-24-2007, 10:16 AM   #4
sigv's Avatar
1963 24' Tradewind
Got a picture?
Thanks for the quick reply - do either of you have a picture of it - will run to Camping world and pick up.
Old 12-24-2007, 10:19 AM   #5
Wayne&Sam's Avatar
Images: 21
Can't give you a photo (the Troutstream is stored for the winter) but I got most of my parts from the hardware store.
Old 12-24-2007, 10:31 AM   #6
Retired.
. , At Large
IIRC, they call it an extendastay, and it retails for about $75. Of course, they may not be talking about what we are talking about. Also they are closed today and tomorrow, at least here.
Old 12-24-2007, 10:37 AM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Camping World had a lot of confusing variations. It was at our local farm fleet store that I found a 'T' to fit at the top of the tank that would allow me to keep the tank hooked up to the trailer and had a side outlet for my Roadtrip grill. I didn't have to have that tank selected for house gas -- I could turn on the tank and it would supply the 25' (?) hose I bought to run to the grill. A significant amount of liquified propane stays resident in the hose -- this setup will give you a bit more odor up in the tank area but I'm getting no soap bubbles. Brass LP fittings are tight like they are and don't use teflon tape ... right everybody?
5 meter Langford Nahanni
Old 12-24-2007, 10:38 AM   #8
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Speaking of that.... Merry Christmas!!!
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 12-24-2007, 10:52 AM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Stay Flow at Camping world comes with a 12 foot hose and the adapter T.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 12-24-2007, 11:30 AM   #10
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Tee AFTER the reg
The safest tee would be one inserted AFTER the Airstream's regulator. That way there would be no LIQUID propane - Only gaseous.
While any form of propane should be handled safely, the LIQUID form has a whole lot more energy than the gaseous form.
Tom
Old 12-24-2007, 11:46 AM   #11
Wayne&Sam's Avatar
Images: 21
Gas (not liquid) stays in the hose in my set up and I did it that way intentionally. It takes a long time to purge the air out of a twelve foot hose each time you want to use it. Maybe that's not so bad on a grill, but I don't want to be yanking on the generator all that time.
Trailer Mount Grill??? 66Overlander LP Gas, Piping, Tanks & Regulators 22 05-01-2016 05:11 PM
Airstream-o-Lantern! A-Merry-Can Our Community 13 11-01-2006 09:51 AM
Gas lantern in '67 Safari - need info airdrmr General Interior Topics 10 08-07-2006 12:36 AM
Gift trailer - propane problems ButchFadely Member Introductions 4 05-28-2006 07:33 AM
propane line under trailer? MrSalt All Argosy Trailers 7 08-21-2004 11:41 PM
