Old 07-06-2011, 07:35 PM   #1
bennyg's Avatar
1973 23' Safari
New Albany , Indiana
Keep old copper plumbing?
hi should I keep my old copper until I am ready to install pex in case I have any questions as to bends and fittings? I have done quite a bit of plumbing but I am clueless when it comes to pex. I have been told right now is a good time to take copper to the recycling center! The copper LP lines are a different beast for me bc I need to learn to bend the lines, but I think it will not be to difficult. Any opinions greatly appreciated. Thanks
bennyg is offline   Reply With Quote
Old 07-06-2011, 07:53 PM   #2
x
XXXX , XXXX
Benny here is a link to the tool I bought to bend the copper lines for the propane gas system. It's not hard to do but careful planing and measuring is needed to get the bend exactly where you want it.
Tube Bender, 1/4, 3/16, 3/8 and 1/2 In Cap - Tubing Benders - Plumbing Tools - 3KE42 : Grainger Industrial Supply
wasagachris is offline   Reply With Quote
Old 07-06-2011, 08:12 PM   #3
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Forget the copper prices you should keep the old copper as a pattern and if there are just a few leaks fix them.
Kevin
kevinb is offline   Reply With Quote
Old 07-06-2011, 08:14 PM   #4
Lothlorian's Avatar
Loganville , Georgia
Find where ever your splits, cut them out and connect them with shark bite fittings. Very easy.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 07-06-2011, 08:17 PM   #5
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
Gas or water? PEX is terrific for H20 systems...I have little experience with it (or it's relatives for use with Propane) use the old as a pattern and you should be fine...
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 07-06-2011, 08:29 PM   #6
rideair's Avatar
I've never seen a mouse chew through a copper line, can't say the same for a plastic one!
I'll go with copper all day long.
Paul Waddell
rideair is offline   Reply With Quote
Old 07-06-2011, 08:57 PM   #7
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Our 65 Safari has all the original copper lines with a few fixes here and there. Still going strong.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 07-06-2011, 09:46 PM   #8
1966 22' Safari
north stonington , Connecticut
PEX is the material of choice when replacing large runs or whole systems. It's easy to work with (after a fashion) and won't freeze and burst (though the fittings can). There are a number of ways to make connections i.e. crimping, expansion, sharkbites, etc., all of which involve a learning curve. Connections from PEX to existing fixtures can sometimes be challenging but can be done. Unless you're a master plumber and fastidious winterizer, PEX is the way to go. That being said, there's no reason to replace an operating copper system for it's scrap value. IMHO
dibAL is offline   Reply With Quote
Old 07-06-2011, 09:54 PM   #9
HollisOR's Avatar
1964 26' Overlander
Dallas , Oregon
PEX is wonderful. I have done copper for years, PEX is so easy, even a caveman can do it. There are some tricks. But nothing Home Depot or Lowes can not fix.
There are PEX fitting that will go from PEX to Copper.
HollisOR is offline   Reply With Quote
copper plumbing in 1965 Trade wind Dr Dan Fresh Water Systems 5 07-14-2011 08:41 PM
Tail-end copper tubing dmand001 Fresh Water Systems 2 06-20-2011 12:49 PM
Help with Plumbing in Long Beach CA! AArchitect Plumbing - Systems & Fixtures 3 06-11-2011 02:18 PM
New plumbing...install filters? aircooled4 Fresh Water Systems 14 05-28-2011 07:16 AM
Interior Plumbing Vent and cap the outside? robwok Roof 5 02-14-2011 01:27 PM
