Old 06-20-2012, 08:36 PM   #1
2004 16' International CCD
Orem , Utah
Just purchased off Amazon 12" gas lines to tank
problem I just found out they are 1/4 inch male threads while I think stock regulator 3/8s. If I buy adapters will the lower volume be an issue. Who makes the correct ones besides marshal.
starcraft is offline   Reply With Quote
Old 06-20-2012, 10:02 PM   #2
1974 Argosy 20
Kooskia , Idaho
The pressure is high, and the volume is low at the tank, so I doubt you would have any problem with volume after the regulator. No idea about the adapter you might need.
Old 06-20-2012, 10:07 PM   #3
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
I wouldn't worry about it at the tanks either just get a 3/8 X1/4 flush bushing, brass, threaded. HD item.Put about 5 wraps of tape on the threads wrapping in a clockwise direction so the tape tightens and draws in as you make up the joint.
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 06-22-2012, 10:46 AM   #4
Orem , Utah
Just got back from HD
Package on olympic hoses say's 1/4 male however I bought 1/4 to 1/8's and it's closer to 1/8. Wont spin in hum 1/4 MIP x 1/8's fip pie hex bushing. Is this proprietary for each manufacter or something. Ok just read hose say's 7/16-24uns
Old 06-23-2012, 08:40 PM   #5
Orem , Utah
House of hose had correct adapter
Compression 7 16's to 1/4 pipe thread $3.50
