05-31-2014, 04:47 PM
#121
2022 Atlas
Homosassa
I turn ours on about 3 days before departure load the food the day before and turn a tank on and make sure that works and depart normally early morning. If I am loading food at destination, I cool as usual but no LP.
Sent from my SCH-I545 using Airstream Forums mobile app
05-31-2014, 06:01 PM
#122
2012 25' Flying Cloud
Moultrie
, Georgia
Is there another option besides arriving with a hot fridge? (Not asking sarcastically.)
05-31-2014, 06:04 PM
#123
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
A three way fridge that is capable of cooling on twelve volts.
I understand that the three way fridges sorta kinda cool on 12 volt.
06-01-2014, 07:15 AM
#124
Alamo Heights
A 12v fridge with a Danfoss compressor.
— David
06-04-2014, 07:07 PM
#125
2014 30' FB FC Bunk
Hoover
, Alabama
I left mine on during last trip - forgot to cut it off during a fuel stop on way down :/
Luckily no kaboom
06-04-2014, 07:32 PM
#126
2013 30' Classic
Greenwood
, Mississippi
It automatically cuts off for 15 minutes at fuel stops.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
06-05-2014, 04:57 PM
#127
2014 23' Flying Cloud
Reed Point
, Montana
I have a new 23 flying cloud.....going off grid next week.
Will the fridge run ok on LP without my generator running.........the owners manual isn't real clear on this point. Up to this point I've had 50 amp service while I camped.
06-05-2014, 06:00 PM
#128
Corona
Luckily no kaboom
That Kaboom is about as likely to happen as the number 2 engine of a 747 aircraft falling on top of your Airstream's air conditioner.
When you refuel your tow vehicle, the fire in your reefer, or furnace, or the water heater, is a long way away from the fuel nozzle.
06-05-2014, 06:42 PM
#129
Alamo Heights
Your modern 2-way refrigerator does require some 12v power to run the control board. If the fridge is all you're using (or if you have solar panels) you should be OK for quite a while, but you'll eventually need something charging the batteries even for just the fridge.
— David
06-05-2014, 07:06 PM
#130
E Pluribus Aluminus
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Yup, the refer will run on LP and you don’t need 50 amp service on a 23’ Flying Cloud, 30 amp will suffice. You will need to select LP on the ‘fridge so it knows what kind of juice to use...
Happy trails.
Jaxon
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
06-05-2014, 07:22 PM
#131
Reed Point
, Montana
Thanks guys.........I won't have any service so I guess the fridge will run only while I have the gen. running.......should be fine. Looks like an amazing campground near the Beartooth in Montana, it's called Woodbine campground a U.S. forest service spot.
06-05-2014, 08:00 PM
#132
Alamo Heights
You misread. The fridge will run off propane as long as you have 12v DC battery power to run the control board. You should be able to charge your batteries on the generator every day or two (depending on what other loads like radio, lights, water pump, fans etc.) and let the fridge run continuously.
— David
06-05-2014, 08:03 PM
#133
E Pluribus Aluminus
1967 22' Safari
2005 30' Classic
Land Of Enchantment
, New Mexico
Your fridge will run on LP also... 12volt is the output of your batteries, keep ‘em charged to handle lights and small drains (like the control board for the fridge) and your LP will run the fridge keeping it cold.
I’m assuming that if you are “off the grid” you at least have solar panels to service the batteries...? If not, the generator will charge them, also.
Jaxon
06-05-2014, 08:42 PM
#134
1973 23' Safari
Indianapolis
, Indiana
I was always afraid to run on propane, using DC while travelling, but often had a dead battery at the end of the trip.
06-05-2014, 08:57 PM
#135
Reed Point
, Montana
Good Copy, thanks for clarifying..........
I appreciate all of the help from everyone!
06-05-2014, 08:59 PM
#136
1972 31' Sovereign
Benton
, Arkansas
JJMorgan,,
You had me going,
I was thinking, hey, I didn't post that....
06-05-2014, 11:03 PM
#137
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Good one. Say, we accidentally left the propane on for a short move from one campground to another last week, and...absolutely nothing happened except our fridge stayed cold. Not a valid statistical sample, but I'm grateful to have achieved a good result like so many others.
06-05-2014, 11:25 PM
#138
1974 Argosy 20
Kooskia
, Idaho
Bigskyrider8: Your refrigerator should also automatically change over from 120 volt electric to propane if you simply turn it on and leave it in the AUTO mode. That way, when you plug into 120 volt power it will use 120 volt power, when none is available, it will automatically switch to Propane
On my 2014 FC 20' you do NOT want to push the "gas" button as that forces the refrigerator to propane, but also cuts the thermostat out of the circuit (strange, eh) so the thing will overcool and freeze everything in the refrigerator. The "gas" button is only for a testing to over ride the thermostat.
This is apparently a new feature on the 2014's and my dealer told me about it. I didn't believe them, but a careful reading of the Dometic manual confirmed what they said.
So, just leave the switch in AUTO and all will work just fine.
And yes the refrigerator takes a small amount of 12 volt power to run the control system, but unless your batteries are very very low, it should not become a problem.
Enjoy the Beartooth Highway and the campgrounds there. Some are very beautiful.
06-06-2014, 01:23 AM
#139
2010 27' FB Flying Cloud
Fraser Valley
, British Columbia
Tow with propane off because I'm cheap and like to make it last as long as possible.
Am schooled in Foodsafe; have never made myself (or anyone else) sick on the road. All it takes is a bit of menu planning, preparation, and observation of portable therometer. Frozen drink boxes make great ice packs. Or else, I just freeze water in large Ziploc bags. Extreme protein perishables like raw chicken are stuffed into AS freezer with lots of ice packs. I have travelled all day, and the packs were still semi frozen (and temp. was well below the mandatory 40F.)
Other things like dairy - I tend to buy on the road. Even though milk and cheese can be frozen, I don't like the thawed taste or texture.
06-06-2014, 05:51 AM
#140
2014 30' FB FC Bunk
Hoover
, Alabama
Also while in tow my truck is charging the batteries a bit so I think it will not cause net drain from that bit of 12v draw
