04-16-2014, 10:48 AM
2007 23' International CCD
cary
, North Carolina
Is it ok to run fridge on propane while towing ?
04-16-2014, 10:55 AM
1974 Argosy 20
Kooskia
, Idaho
You may wish to do a search of the Air Forums on the topic. It has been covered many times.
In brief, most find it to be not an issue for them, some however are violently opposed to the idea. You will not find a common ground between the two sides.
I am with the majority, and tow with my refrigerator on propane, and have for 35 years of my RV experience.
But then I live dangerously, and have an Andersen hitch (ducks, and grins).
04-16-2014, 10:56 AM
Alamo Heights
This is a bit of a religious issue for some.
Personally, I always run the fridge on propane when towing. It's too hot in TX for much of the year for it to stay cold otherwise unless it's a very short trip. If I'm pulling up in a gas station such that the trailer will be near a pump, I shut off the flame while fueling.
— David
cary
, North Carolina
Cool (pun intended). Many thanks...and I'll check out the other postings.
04-19-2014, 12:11 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I always do.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
04-19-2014, 12:14 PM
Corona
Thats been done ever since the fridges have been able to run on LPG.
So that's at least 6 decades.
That is also how the trailer was designed.
04-19-2014, 12:23 PM
1984 31' Airstream310
Ajo
We do, and I agree with shutting it down when fueling.
04-19-2014, 01:35 PM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
I just put the fridge on auto when heading south for the winter and turn it off when we get home in the spring, period.
Antique Pedaler
2021 Caravel 20 FB
04-19-2014, 02:34 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Sometimes...
Aaron
WBCCI #XXXX AIR #2495
04-19-2014, 03:01 PM
2011 30' Flying Cloud
Arvada
We always travel with the fridge running.
04-19-2014, 03:24 PM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
I have been doing it for over 40 years. I have yet to blow up a gas station and also have not gotten food poisoning since my food is cool.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
04-19-2014, 04:42 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I am not worried about me blowing up the gas station... just the idiot next to me that wanders away while the pump is running.
Aaron
04-19-2014, 05:01 PM
1977 31' Excella 500
Berkeley Springs
, West Virginia
Yes
Absolutely it is OK. If not, why have LPG refrigerators at all?
I tow with a diesel. I used to turn the 'fridge off when I refueled, but I've stopped doing that too. If you throw a match into a bucket of kerosene, it just burns. It doesn't explode.
If you tow with a gasser, you probably should turn the 'fridge off before you pull up to the pump, but there's a 99.9% chance it'd be just fine if you didn't.
See you on the road,
- Jim
04-19-2014, 05:38 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
'cause battery powered wouldn't last too long? Not all of us camp where there are hookups. Prefer to get away from the crowds...
Aaron
04-19-2014, 06:41 PM
Senior Member
2012 27' FB Eddie Bauer
Sparks
, Nevada
Always! But then again I run the heater going down the road in cold weather as we'll....
04-19-2014, 07:24 PM
Corona
Well done.
Learning how to use an Airstream, is very important.
Some owners have learned, as you have, so that you can enjoy all it offers.
Others still try to invent the wheel.
Oh well, to each his own.
And so it is.
04-19-2014, 07:35 PM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
I tow with a diesel as well, but I believe that there is a circuit set up in the Dometic so that when you are on propane and 12V (e.g. towing), and you shut down your engine (no power being seen from your car on the 7 pin), there's an automatic time delay for restart on the fridge....specifically to allow people to refuel without having to go in and manually shut off their fridge. Pretty sure this is in my Domectic owners manual.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
04-19-2014, 08:31 PM
2013 30' Classic
Greenwood
, Mississippi
Depends on if there are groceries in there. Tomorrow- yes, I will be traveling with the refrigerator on. I turned it on yesterday hooked up to shore power in the driveway to let it get to the proper temperature. I turned the gas on just now so I won't forget tomorrow when we drive away.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
04-19-2014, 08:36 PM
2018 30' Classic
Ivins
, Utah
And you can be sure, if there was the slightest risk of danger while towing with the refrigerator in LP mode, that the refrigerator manufacturer's and Airstream's lawyers would have big red caution placards plastered in the rig and in the manuals....
04-19-2014, 08:51 PM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
I have visited and posted on lots of automotive related forums, I don't think I have ever seen one with so many opinionated people who are so sure that there is only one "proper" way to do things, and are so sure that so many things that are done everyday cannot be done.
