Old 04-25-2014, 08:02 PM   #113
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Originally Posted by DKB_SATX View Post
This is a bit of a religious issue for some.
Personally, I always run the fridge on propane when towing. It's too hot in TX for much of the year for it to stay cold otherwise unless it's a very short trip. If I'm pulling up in a gas station such that the trailer will be near a pump, I shut off the flame while fueling.
Ditto !
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 05-31-2014, 08:17 AM   #114
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
so did we every figure out if it was safe to travel with the LP tanks on or not..
I would figure just reading this long thread you would be more likely to sustain damage with a tire, especially the GM, blow out than a LP gas leak or worse.. there was an RV on fire in the news a couple days ago that blocked the interstate. In looking at the picture its most likely cause was tire and/ or bearings overheating. do not know for sure just looking at where fire started from news reports..
Here's my non official and non RV owning person take on this..
If you are going a short distance, ie. 3-5 hrs, and the weather is mild and the reefer has been pre-cooled and you have a good amount of cold and frozen item in it then you can run with LP off..
On the other hand if you are traveling 4-6 hrs and the weather is warm to hot and the reefer is pre-cooled and you have a good amount of cold and frozen stuff you can run with LP on or off.
So i guess it depend on U if you want to run LP reefer on or not. but not in canada eh..
I would be more worried about the tires than the LP issue, not to mention the other idiots on the road doing stupid stunts in front, beside you.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 05-31-2014, 08:38 AM   #115
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I'm still runnin' down the road with the fridge on...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-31-2014, 11:16 AM   #116
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We tow with the fridge running if we have food inside it.
Old 05-31-2014, 11:50 AM   #117
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
We tow with the fridge on when food is inside. I usually only open one tank's valve unless we've been camping for more than 3 or 4 days. When I pick the trailer up from storage I buy 2 small bags of ice, one for the fridge and one for the freezer. When I get home I turn on the LP and set the fridge to "Auto'. The refrigerator works better / cools faster on LP than 120Volt. When the fridge gets down to temp, I divide the remaining ice into smaller bags and stow them in the freezer for future happy hour use. If the trailer will be parked at home for more than a day before departure, I plug in to 120V and the fridge automatically switches to 120V operation. When we depart, the fridge reverts to LP until we plug in at the next stop. I have installed Acu-Rite wireless thermometers in the freezer fridge and keep the receiver above the vent hood holding on with the magnets. When we are on the move we keep the receiver in the cab of the truck. I leave the alarms on to alert us if the fridge rises above 40 degrees or the freezer rises above freezing. The Acu-Rite also doubles as a good indoor outdoor thermometer if you turn the alarms off. Amazon.com: ACU_RITE Refrigerator/Freezer Wireless Digital Thermometer 00986: Kitchen & Dining
SuperTrouper is offline   Reply With Quote
Old 05-31-2014, 12:14 PM   #118
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
We've always towed with the fridge on propane w/o out issue. We are leaving in two weeks going out to Manitoba and Sask to visit wife's family, and though it might be neat to take the SS Badger across Lake Mich. from Ludington to Manitowoc. It's a four hour ride and I just happen to think about the fridge running on LP, to which they said, NO, it needs to be turned off, so we will have to careful about what we carry until we get to Wisc.
goshawks00 is offline   Reply With Quote
Old 05-31-2014, 12:27 PM   #119
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We run with LPG on, although I only run with one tank open. I turn off the fridge during refueling stops. Typically rv's kept in enclosed areas like goshawks00 noted or when towing through tunnels might require you to turn off anything with an open flame which includes an RV refrigerator.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 05-31-2014, 01:40 PM   #120
m.hony's Avatar
2013 30' Classic
I try to turn it on about 12 hours prior to departure so it will be cold when I put the groceries in. Then off down the highway with it on...
TAC #MS-10
Airforums #70955
Old 05-31-2014, 04:47 PM   #121
2012 30' Classic
Homosassa , Florida
I turn ours on about 3 days before departure load the food the day before and turn a tank on and make sure that works and depart normally early morning. If I am loading food at destination, I cool as usual but no LP.
Sent from my SCH-I545 using Airstream Forums mobile app
Tater is offline   Reply With Quote
Old 05-31-2014, 06:01 PM   #122
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Is there another option besides arriving with a hot fridge? (Not asking sarcastically.)
GAStreamin is offline   Reply With Quote
Old 05-31-2014, 06:04 PM   #123
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A three way fridge that is capable of cooling on twelve volts.
I understand that the three way fridges sorta kinda cool on 12 volt.
Old 06-01-2014, 07:15 AM   #124
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
A 12v fridge with a Danfoss compressor.
— David
Old 06-04-2014, 07:07 PM   #125
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I left mine on during last trip - forgot to cut it off during a fuel stop on way down :/
Luckily no kaboom
PharmGeek is offline   Reply With Quote
Old 06-04-2014, 07:32 PM   #126
m.hony's Avatar
2013 30' Classic
It automatically cuts off for 15 minutes at fuel stops.
TAC #MS-10
Airforums #70955
Keeping fridge cold while towing... HansenClan Refrigerators 9 08-22-2012 01:35 PM
how much propane to run a fridge? Rollerboy Refrigerators 4 10-23-2007 10:50 AM
Running the fridge while towing? andyfuson General Motorhome Topics 15 09-20-2003 12:15 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
