Old 06-05-2014, 04:57 PM   #127
2014 23' Flying Cloud
Reed Point , Montana
I have a new 23 flying cloud.....going off grid next week.
Will the fridge run ok on LP without my generator running.........the owners manual isn't real clear on this point. Up to this point I've had 50 amp service while I camped.
Bigskyrider8 is offline   Reply With Quote
Old 06-05-2014, 06:00 PM   #128
Originally Posted by PharmGeek View Post
I left mine on during last trip - forgot to cut it off during a fuel stop on way down :/
Luckily no kaboom
That Kaboom is about as likely to happen as the number 2 engine of a 747 aircraft falling on top of your Airstream's air conditioner.
When you refuel your tow vehicle, the fire in your reefer, or furnace, or the water heater, is a long way away from the fuel nozzle.
Old 06-05-2014, 06:42 PM   #129
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Your modern 2-way refrigerator does require some 12v power to run the control board. If the fridge is all you're using (or if you have solar panels) you should be OK for quite a while, but you'll eventually need something charging the batteries even for just the fridge.
— David
DKB_SATX is online now   Reply With Quote
Old 06-05-2014, 07:06 PM   #130
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Yup, the refer will run on LP and you don’t need 50 amp service on a 23’ Flying Cloud, 30 amp will suffice. You will need to select LP on the ‘fridge so it knows what kind of juice to use...
Happy trails.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 06-05-2014, 07:22 PM   #131
Thanks guys.........I won't have any service so I guess the fridge will run only while I have the gen. running.......should be fine. Looks like an amazing campground near the Beartooth in Montana, it's called Woodbine campground a U.S. forest service spot.
Old 06-05-2014, 08:00 PM   #132
DKB_SATX's Avatar
1976 Argosy 28
You misread. The fridge will run off propane as long as you have 12v DC battery power to run the control board. You should be able to charge your batteries on the generator every day or two (depending on what other loads like radio, lights, water pump, fans etc.) and let the fridge run continuously.
— David
Old 06-05-2014, 08:03 PM   #133
E Pluribus Aluminus
Jaxon's Avatar
1967 22' Safari
2005 30' Classic
Rockport , Texas
Your fridge will run on LP also... 12volt is the output of your batteries, keep ‘em charged to handle lights and small drains (like the control board for the fridge) and your LP will run the fridge keeping it cold.
I’m assuming that if you are “off the grid” you at least have solar panels to service the batteries...? If not, the generator will charge them, also.
Bill & Kim
Old 06-05-2014, 08:42 PM   #134
1973 23' Safari
Indianapolis , Indiana
I was always afraid to run on propane, using DC while travelling, but often had a dead battery at the end of the trip.
JJMorgan is offline   Reply With Quote
Old 06-05-2014, 08:57 PM   #135
Good Copy, thanks for clarifying..........
I appreciate all of the help from everyone!
Old 06-05-2014, 08:59 PM   #136
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
JJMorgan,,
You had me going,
I was thinking, hey, I didn't post that....
Old 06-05-2014, 11:03 PM   #137
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Good one. Say, we accidentally left the propane on for a short move from one campground to another last week, and...absolutely nothing happened except our fridge stayed cold. Not a valid statistical sample, but I'm grateful to have achieved a good result like so many others.
Old 06-05-2014, 11:25 PM   #138
1974 Argosy 20
Kooskia , Idaho
Bigskyrider8: Your refrigerator should also automatically change over from 120 volt electric to propane if you simply turn it on and leave it in the AUTO mode. That way, when you plug into 120 volt power it will use 120 volt power, when none is available, it will automatically switch to Propane
On my 2014 FC 20' you do NOT want to push the "gas" button as that forces the refrigerator to propane, but also cuts the thermostat out of the circuit (strange, eh) so the thing will overcool and freeze everything in the refrigerator. The "gas" button is only for a testing to over ride the thermostat.
This is apparently a new feature on the 2014's and my dealer told me about it. I didn't believe them, but a careful reading of the Dometic manual confirmed what they said.
So, just leave the switch in AUTO and all will work just fine.
And yes the refrigerator takes a small amount of 12 volt power to run the control system, but unless your batteries are very very low, it should not become a problem.
Enjoy the Beartooth Highway and the campgrounds there. Some are very beautiful.
Old 06-06-2014, 01:23 AM   #139
Fly at Night's Avatar
2010 27' FB Flying Cloud
Fraser Valley , British Columbia
Tow with propane off because I'm cheap and like to make it last as long as possible.
Am schooled in Foodsafe; have never made myself (or anyone else) sick on the road. All it takes is a bit of menu planning, preparation, and observation of portable therometer. Frozen drink boxes make great ice packs. Or else, I just freeze water in large Ziploc bags. Extreme protein perishables like raw chicken are stuffed into AS freezer with lots of ice packs. I have travelled all day, and the packs were still semi frozen (and temp. was well below the mandatory 40F.)
Other things like dairy - I tend to buy on the road. Even though milk and cheese can be frozen, I don't like the thawed taste or texture.
Fly at Night is offline   Reply With Quote
Old 06-06-2014, 05:51 AM   #140
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Also while in tow my truck is charging the batteries a bit so I think it will not cause net drain from that bit of 12v draw
PharmGeek is offline   Reply With Quote
Keeping fridge cold while towing... HansenClan Refrigerators 9 08-22-2012 01:35 PM
how much propane to run a fridge? Rollerboy Refrigerators 4 10-23-2007 10:50 AM
Running the fridge while towing? andyfuson General Motorhome Topics 15 09-20-2003 12:15 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
