09-24-2017, 08:54 AM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
Installing Propane Quick Disconnect
I am running new gas lines and was wondering if anyone has installed a quick connect for a grill on a older model Airstream, I have a 1972 Sovereign and wanted to put one on while I was installing for future use. Was trying to figure a good place to install it on the unit. Any help and pictures would be a great help. Could not find any post referencing this.
09-24-2017, 09:30 AM
2002 30' Classic S/O
Fleming Island
I put a Tee fitting at the junction of the flexible line from the tanks and the hard line to the rest of the trailer. I use a Camco Olympian grill that has a mounting rail that I screwed into the horizontal rib under the window in front of the door. I drape the hose from the grill over and behind the segment protector and hook it up to the fitting. I used a Camco quick disconnect fitting I got on Amazon.
Al
09-24-2017, 10:56 AM
Princeton
, New Jersey
This is what I use.
http://www.adventurerv.net/addatee-p...source=Froogle
I think the hose I am using is longer but not a big thing. I would not consider a true Quick Disconnect for a trailer installation for reasons of possible very small leakage that would drain the tank without you knowing. A half cooked burger is not worth the convenience the Quick Disconnect might give.
Keep in mind this only works off one of the tanks so I have to keep an eye on that tank level.
2004 Excursion 4x4
09-24-2017, 04:22 PM
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy
, Tennessee
I was thinking about using the Quick Connect with Valve Shut Off that VTS sells since it has a valve to isolate the gas. Has anyone used their quick connect valve.
09-24-2017, 04:27 PM
1974 27' Overlander
Baltimore
, Maryland
Mine is on the street side bumper.
09-25-2017, 12:36 PM
1999 25' Safari
Okeechobee
I thank that line is on the sidewalk side..
09-25-2017, 07:27 PM
1972 27' Overlander
Greenwood
, South Carolina
Quick LP Connection
Recently installed this on my '72 Overlander. Cut into copper gas line and installed a flare "T." Placed a QC on one end of copper tubing and a flare with flare ""nut" that connects into the "T." If concerned about this when traveling, I remove this at the T and replace with a flare cap. This was installed on the curbside about inline with front tire.
09-25-2017, 07:29 PM
1974 27' Overlander
Baltimore
, Maryland
Right. Curb side. Starboard. Passenger. My mistake.
09-26-2017, 09:16 AM
1972 27' Overlander
Greenwood
, South Carolina
The valve that I used looks like yours. There are several on the market that have a cut-off made into the QC and a 3/8 female pipe thread on one end.
