Old 01-11-2011, 04:28 PM   #57
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hey, Lindy! As a quilter, I know you probably have freezer paper for templating. You can use that for patterns for your floor tiles, at least to rough cut them. Easier than using something stiffer, and you can finesse them as you go. I can't help you with electrical or gas, but, by golly, I can help you with templates!
Kay
Old 01-11-2011, 05:28 PM   #58
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Hi Lindy; Sorry you're having trouble.
"but what do you do when there is a dip or two or three between the pattern and the wall (or in my case, the ceiling?) There's nothing there to mark on. Do you add another piece to the back of it and mark that?"
You mark on the part of the pattern that is touching or close to touching the wall, what ever part the pencil will make a mark on; then remove the part outside the mark. When you put the pattern against the wall again those gaps you mention will be smaller. Just keep marking the pattern wherever the pencil will make a mark, then cut those high spots off. You will get to the point where you can draw a line on the pattern that is continuous and when that happens and you cut on that line it will match the wall.
"I did use your method this afternoon and got an "almost" fit but I do have several dips where I need to add to rather than take away from the pattern."
Since the pattern material is a throw away item, just keep cutting the high spots of the pattern off until you have eliminated the gaps.
TG Twinkie is online now   Reply With Quote
Old 01-11-2011, 09:06 PM   #59
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Kay
Ah! I certainly can use freezer paper - and you KNOW I have some!
Thanks for the great hint!
Lindy
lucymcdog is offline   Reply With Quote
Old 01-11-2011, 09:09 PM   #60
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
I think part of the problem was that it was 16 degrees and I was trying to get something done with frozen hands. What you say makes sense so I will heat up the man-cave tomorrow and try to do a better job. And I won't cut from the birch until I'm certain it will work.
Lindy
Old 01-11-2011, 10:11 PM   #61
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Good idea, the birch is much to expensive to be wasting. Now I wish I would have made a video of how the process works. They say a picture is worth a thousand words. That must mean a video is worth 10,000 words.
LOL
Old 01-12-2011, 06:37 AM   #62
Minno's Avatar
1972 31' Sovereign
btw - Kay is making all the templates for Little Girl now...
Chris
Old 01-12-2011, 07:25 AM   #63
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Chris
She wouldn't by chance like to come visit Saguache, CO for a week or so, would she?
Old 01-12-2011, 07:36 AM   #64
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by lucymcdog View Post
The inverter is a 350 Watt and the only thing I could find was the cigarette lighter plugger-inner. I'm almost sure there are some wires somewhere that clip on. I suppose, if I needed them, I could always put something together.
Careful, what looks like the "cigarette lighter plugger-inner" is not. It is a 12v DC outlet. If you put a cigarette lighter in there is will overheat.
Old 01-12-2011, 01:40 PM   #65
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
G-o-o-l-l-l-e-e-e!
Chris
The tile is down on the potty box and is absolutely PERFECT - thanks to the easy-to-make templates made from freezer paper!
"You mark on the part of the pattern that is touching or close to touching the wall, what ever part the pencil will make a mark on; then remove the part outside the mark. When you put the pattern against the wall again those gaps you mention will be smaller. Just keep marking the pattern wherever the pencil will make a mark, then cut those high spots off. You will get to the point where you can draw a line on the pattern that is continuous and when that happens and you cut on that line it will match the wall."
The template for the bathroom wall is without dips, bumps or gaps thanks to the excellent instruction received in how to cut those dang curves. We will cut the birch this afternoon.
THANK YOU - YET AGAIN!
(It takes a village to restore a vintage Airstream)
Old 01-12-2011, 03:20 PM   #66
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Glad it looks like it will work out. Post some photos of how it came out.
If the guy in the hardware store only knew how talented you are!
Old 01-18-2011, 05:16 PM   #67
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
The perfect wall and floor!
Well, the wall and floor are more perfect than the photographer.
Name:	the perfect wall.jpg
ID:	119622   Click image for larger version
Name:	the perfect floor.jpg
Old 01-19-2011, 06:37 AM   #68
Minno's Avatar
1972 31' Sovereign
That looks great!!!!!!!!
Chris
Old 01-19-2011, 07:03 AM   #69
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Wow!!
BEAUTIFUL!! Job Lindy; With the skills you've learned here the dinette should be a walk in the park.
Old 01-22-2011, 11:12 PM   #70
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
That looks beautiful.
NicheVintage is offline   Reply With Quote
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
How to Light the Pilot in the Oven lcurrie Stoves, Ovens & Microwaves 3 08-01-2011 07:16 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
