Old 02-12-2014, 03:54 PM   #1
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Installing PortableCatalytic Heater in Rear Beadroom
Has anyone tried connecting a 3000 btu portable catalytic heater connection in the rear bedroom of a 1994 34 Classic? Getting ready to do it if I get positive feedback and some help with instructions for the best way to do it. Regards,
Don Hetzler
Emh142 is offline   Reply With Quote
Old 02-12-2014, 04:23 PM   #2
Central , Mississippi
I'm not sure where one would fit. Rear facing on the bathroom wall up pretty high?
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-13-2014, 09:54 AM   #3
1998 30' Excella 1000
Livingston , Texas
I would think long and hard before I put a catalytic heater in a bedroom. Maybe I worry too much, but what if I forgot to crack open a window, or an unexpected wind driven snow event blocked it, oh, and the oxygen depletion sensor on the heater happened to malfunction. Like I said, maybe I worry too much, but I'd keep it in the living area.
Siegmann is offline   Reply With Quote
Old 02-13-2014, 04:56 PM   #4
Gainesville , Florida
These things were standard for years in AS, they worked well. Jim
Old 02-13-2014, 04:58 PM   #5
PhilipKS's Avatar
1999 34' Excella
NE Central , Kansas
Post pictures and a review if you do the install! Thanks.
AIR 57698, TAC NM-9. http://www.flickr.com/photos/philipks/
PhilipKS is offline   Reply With Quote
Old 02-13-2014, 08:21 PM   #6
PopHetzler
Emh142's Avatar
Troy , Ohio
I'm thinking of a free standing 3000btu with an extension of the gas line either through the cupboards and out the wardrobe on the curb side bedroom bulkhead or outside line into the wheel well in the wardrobe the through the bulkhead. Anyone tried this???
Old 02-14-2014, 01:16 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Maybe I am paranoid too, but I would not put any unvented gas heater in any camp trailer. A very small area combined with the potential air tightness of an Airstream might spell disaster.
It only took a few minutes of cooking with two stovetop burners to set off my carbon monoxide detector.
I shopped long and hard for the right vented heater, and an electric space heater can work fine in a bath when shore power is available.
Old 02-14-2014, 06:20 AM   #8
All you vintage people, how well did these work in vintage AS? I had on in a 1973and it worked great. Just pop a vent open a little. Never had any kind of dtetctor go off. What about the rest if you? Jim
Old 02-14-2014, 06:22 AM   #9
Don Hetzler
Two problems.
1. Fire hazard.
2. LPG leak.
Old 02-14-2014, 07:15 AM   #10
r carl's Avatar
Lin , Ne
Originally Posted by Inland RV Center, In View Post
Two problems.
1. Fire hazard.
2. LPG leak.
Other than those 2 problems, what else can you tell us about living with a catalytic heater in your camper?
Old 02-14-2014, 07:22 AM   #11
Fire hazard is common sense, keep flammables away. Leaks not a problem installed properly! Jim
Old 02-14-2014, 07:39 AM   #12
1972 21' Globetrotter
Wylie , Texas
Are the hazards any less for a furnace? The more I hear about LPG appliances, the more I want to steer clear of the extended use ones ( heater, refrig).
rippie is offline   Reply With Quote
Old 02-14-2014, 07:47 AM   #13
A portable heater of any kind is not a good idea in an RV.
Way to many ways to cause a fire.
A catalytic heater, is very useful, but it should be mounted permanently so that a fire is not likely, unless things are carelessly placed near it.
On the other hand, the furnace, depending on it's rating, puts out 10 to 20 times the heat (btu) that a catalytic does, as well as circulating the heat.
Or, if you wish to take the chill off the coach, you can use the AC as a heat source.
The only real advantage of a catalytic heater is that it does not use any battery power.
Old 02-14-2014, 08:05 AM   #14
Those same things are a hazard in your home as well.
Fixed locations for heat sources as well as proper ventilation for the exhaust are the keys for safety, in a home or RV.
The added issues for an RV is vibration. It can and does cause things to go astray, such as LPG leaks.
Checking an Airstream for a LPG leak is very simple.
Shut off all the LPG appliances, including the LPG tanks.
Look at the LPG regulator visual pressure indicator.
When the LPG system is pressurized, it will show "green", meaning you have pressure from the tank, that has pressurized the LPG lines.
Check that indicator after an hour or two. If it's still green, you have no leaks. If it's (red) the LPG pressure was depleted because of a leak.
Should you have a LPG leak, take a squirt bottle with some water and liquid detergent in it. Spray all the LPG fittings until you find the culprit.
Fix what ever you found leaking, and then repeat the test.
I have always suggested that the above test should be done yearly, or if a leak is suspected.
Things can get loose in an RV because of vibration, which can come from excessive rated tow vehicles, excessive rated hitch bars, lack of proper running gear balance, as well as bad rubber rods in torsion axles.
Peace of mind is always welcome.
And so is safety.
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Water heater battery drain Bohemian Batteries, Univolts, Converters & Inverters 5 10-27-2011 12:22 PM
Water Heater Seal Ditter Water Heaters, Filters & Pumps 6 10-24-2011 03:13 PM
Dometic RM100 AC heater, big trouble Jim in Pima Refrigerators 15 09-30-2011 10:53 AM
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
