Old 02-14-2014, 08:23 AM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
I agree with Andy that heaters should be installed in a location where they are away from combustible things, particularly draperies and bed linens.
I'm not a fan of catalytic heaters for reasons I've written about elsewhere at length; there are better alternatives for boondocking.
But if cats are installed they should not be in the bedroom. Too easy to end up with a sheet, blanket, or article of clothing in contact with them.
Old 02-14-2014, 11:06 AM   #16
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I have an Olympic on both my 34' and have often thought of installing a second in each stateroom. The radiant heat is great. Safety sense should prevail!
My only complaint comes from the moisture accumulation from the propane. A vent left open solves this but lets out heat.
I think I'm opting for a tiny wood stove in my Classic just to avoid messing with lpg plumbing.
Old 02-16-2014, 06:58 PM   #17
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Smile Thanks
THINK I'll move on to replacing the bathroom flooring. The heater can wait a while but it would really have come in handy in the boonies for two weeks with temps approaching freezing each night with no generators.
Emh142 is offline   Reply With Quote
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Water heater battery drain Bohemian Batteries, Univolts, Converters & Inverters 5 10-27-2011 12:22 PM
Water Heater Seal Ditter Water Heaters, Filters & Pumps 6 10-24-2011 03:13 PM
Dometic RM100 AC heater, big trouble Jim in Pima Refrigerators 15 09-30-2011 10:53 AM
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
