Your work looks really nice. I have a 92 with that same flimsy bracket. I'm redoing mine with the same Campco regulator you used. I also bought two 90-degree elbows so the lines would come off the top and allow the regulator to nestle in between the tanks. The problem I'm having is that, even after several tries, I always end up with leaks where the original fittings that came on the Campco screw into the 90-degree elbows. The only thing I can think of is maybe the Chinese fittings from Home Depot have sloppy tolerances or something like that. Or maybe I need to use a different paste. I used Harvey's TFE paste on the male threads, but those two joints keep leaking. The sealant/adhesive the factory used to hold those two fittings into the regulator body looked more like an epoxy to me. Any ideas? Where did you buy your fittings? Are they American made? Any help or ideas would be really appreciated.
