02-12-2008, 07:26 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
Inland RV- need hose
Andy I have a 1982 Excella (made in Dec. 81) it has a 5/8 inch propane line from the regulator back to the coach. I need the 18 inch 5/8 hose from the regulator to the copper line. It has a 1/2 inch pipe thread that screws into the regulator and a 5/8 inch female flare that ties to the copper line via a 5/8 male to male adapter. I can't find one anywhere!
02-12-2008, 08:09 PM
Retired.
, At Large
You will probably get a quicker response if you contact Inland Andy through his website, Airstream Innovations at Inland RV Center, Inc. (951) 734-8130.
02-12-2008, 08:27 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
I called today but never got a call back. I guess I can try again in the AM. 5/8 is a odd size for some reason most people carry 1/2 then go to 3/4. It would be great if someone would put together a kit with all the rubber propane hoses for an Airstream by year model I would buy one.
02-12-2008, 08:35 PM
I had one special built by a local hose company. It wasn't cheap. I think it cost about $20.
02-12-2008, 08:40 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
I live in a small town so all I could try was Lowes and the local propane companies (2). Asheville is about 50 miles I may have to try it out. Most of the time I get my parts off the internet, no gas to burn and it comes right to your door.
02-12-2008, 08:51 PM
I got mine through the local propane supplier. The hose company doesn't do retail. I paid the propane supplier, he ordered it, I drove over and picked it up the next day.
I would definitely talk to your local propane supplier. You could spend all day driving around Asheville and still strike out.
02-12-2008, 09:04 PM
1971 27' Overlander
Central
, Ohio
Why not just reduce the line to 1/2. The 5/8 to 1/2 fittings can be found. I started to do that with mine last year. We have a solid 5/8 copper tube where you have a flex line. I ended up not changing it out - just put new fittings on the upper end. If you can't find the 5/8 fittings let me know - I have some laying in the truck and could find you some more I'm sure. There's an old line RV dealer here that still has the stuff. That said, I'm not sure if there is some real need for the short line to be 5/8ths..
02-12-2008, 09:12 PM
. . . or you could hop on US64, drive on over to Bat Cave and see if RichardT would loan you one from his Airstream fleet.
02-13-2008, 05:41 AM
Retired.
, At Large
...Just don't take your Airstream with you on that road... Ask how I know...
02-13-2008, 07:23 AM
We want pictures!
02-13-2008, 08:14 AM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
I went back to my propane dealer and he came up with this fix. A stainless line.
02-13-2008, 06:15 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
The hose pictured above will not work. Inland RV called and said it had to be rubber to meet code. So I am back at square one and out 25 bucks for a hose I can't use. Inland said that 3/8 was big aplenty for a pigtail. So I am looking around the plant where I work to see what I can find. Seems like a poor boy always has a hard time!
02-13-2008, 07:03 PM
Retired.
, At Large
If that's a rubber hose, why not go to a shop with your old hose, and have them put a new hose on the fittings? It will probably cost you all of $10 or so to do...
02-13-2008, 07:46 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
They don't have a way to make any. I will try the welding shop in the AM.
02-13-2008, 07:47 PM
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin
, 28734
This is just a one mule town.
