Old 04-28-2016, 09:21 AM   #15
Plasma800's Avatar
houston , Texas
Originally Posted by KJRitchie View Post
If in Store then the battery wouldn't be charging via the converter/charger. For something that you can smell at a 100f distance I would think its propane. Is one tank empty now and you are running off the other tank? The additive to propane to give it the smell can linger on adjacent parts if there is a leak. Was the hose connection on tight? Do the hose look in good shape.
My brother in laws Class C had a propane leak from the built in tank and you could smell it as soon as you rounded the curb side back end. He had to get the tank replaced. We never found the leak but there was a lot of rust and we suspected a pin hole leak in the tank somewhere out of sight. He would loose noticeable amounts of propane.
You can remove the tanks and brush on soapy water to all the fittings and weld marks on the tanks to check for leaks
Kelvin
Well I'm pretty sure that when I came home from my last trip... i failed to put the switch back into STORE mode.... Matter of fact, it might have been in USE mode for the entire length of the trip (6 days) while plugged in at a campground.
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 04-28-2016, 09:24 AM   #16
Plasma800's Avatar
houston , Texas
Considering that the tanks have never been filled, and my regulator has never gone red.... I would guess there is no leak in the tank itself.
I wondered if on the drive home I hit something in the road that caused a leak, but the trailer has been in my driveway for another 5 days since returning, with the smell only appearing yesterday.
I had just read the post on regulators failing, and immediately jumped to that as my first conclusion.
But at this point, I might be leaning more towards the batteries.
I'm about to go hook all the propane back up, test the regulator, and see if the smell reappears.
'15 27fb Signature
Old 04-28-2016, 09:49 AM   #17
Gainesville , Florida
In a severe case the batteries can be deformed on the outside. Be careful!
Old 04-28-2016, 10:22 AM   #18
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Overcharged batteries release hydrogen sulfide, which smells exactly like rotten eggs. It's a similar smell to the odorant they use in propane, but not exactly the same. Some folks noses can tell the difference, and some cannot.
Your dry cells and batteries that won't hold a charge certainly lead one to think in that direction.
I'd suggest carefully removing the batteries from the trailer and moving them to a location well away from the propane tanks. Then, after a while, you should be able to tell if the smell follows the batteries or stays around the propane bottles.
As Protag suggested, air out your nose in fresh air for a while before the next test sniff.
Treat both the batteries and the propane tanks as sources of flammable gas for safety reasons. Out gassing batteries can explode.
Old 04-28-2016, 10:28 AM   #19
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Plasma-
My money is on the batteries being toast. Your converter (if it's still the factory unit) has cooked them. Order the replacement "Smart" three stage converter guts from Best Converter, put in two new Group 24s (27s if you modify your box-search on AF for how), leave the switch in "use" forever, and rock on ...............
Kinda same thing happened to us.........so it's a safe bet. Since doing the above, I hardly ever even add water to our batteries, and we're plugged in 24x7 in the barn.
ShinyPete is offline   Reply With Quote
Old 04-28-2016, 02:39 PM   #20
2005 22' International CCD
Cambria , California
Soap test
For the propane issue, put some sudsy dish washing soap with water into a spray bottle. Spray any propane connections or lines that you can and look for a slow bubble.
Ziggy2 is offline   Reply With Quote
Old 04-28-2016, 04:53 PM   #21
2016 25' Flying Cloud
Black Diamond , Washington
Use/store
The "use" switch should be left on even on shore power... Not in "store". Your batteries will not charge ifin store mode. I agree just stay in use mode.
toothpull is offline   Reply With Quote
Old 04-28-2016, 05:08 PM   #22
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Sounds like batteries to me too. The batteries may have been treated badly at the dealer and by the time you got them, they were half shot anyway.
As for propane, I had a number of small leaks on the propane lines under the trailer and had to tighten all the fittings after checking them with soapy water, my nose and if nothing else detects propane escaping, a match will (by the time you check with the other methods, it is obvious no large amount is leaking). I fixed the leaks and used vinyl tubing around the propane lines secured in various ways, mostly with adjustable clamps (once called airplane clamps and now called hose clamps). The vinyl reduces the risk of damage from rocks.
Sounds like you hardly ever use the stove or furnace.
Gene
Gene
Old 04-28-2016, 05:17 PM   #23
1972 27' Overlander
Denver , North Carolina
If it smells like rotten eggs it may be your battery.
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 04-28-2016, 06:08 PM   #24
Plasma800's Avatar
houston , Texas
Gene
Surprisingly, we used it quite a bit... I fully expected to refill the tanks twice by now.
Time for some new batteries I guess... lesson learned.
'15 27fb Signature
Old 04-28-2016, 10:11 PM   #25
1973 31' Sovereign
Middletown , California
If the water level is different in different cells something is wrong with your batteries. Especially if one or more cells were empty. Once the water drops below the tops of the plates there is probably damage being done that the battery might not recover from. If they were mine I'd fill the cells if there is no signs of a leak or warping and check the cells with a hydrometer and then charge the batteries and check again with the hydrometer. Good chance the batteries are toast. Be careful for the acid and don't make sparks!
ijustlee is offline   Reply With Quote
Old 04-28-2016, 10:22 PM   #26
Plasma800's Avatar
houston , Texas
yeah I have a feeling they're toast. Going to pick up a hydrometer tomorrow and test each cell
'15 27fb Signature
Old 04-29-2016, 06:50 AM   #27
Zil
egg harbor city , South Jersey
Originally Posted by Plasma800 View Post
checked my batteries, and I would describe a cell or two as "bone dry"
You don't have to test your batteries. They are done. Get new batteries and also determine if your charging system is faulty. The next step in your battery failure story would be an exploding battery. Please be careful, battery acid will blind you.
Zil is offline   Reply With Quote
Old 04-29-2016, 08:31 AM   #28
Plasma800's Avatar
houston , Texas
alright, I've pulled the batteries and heading to Interstate in a few. From the outside, they look brand new, no swelling or sweating. But I'm going to get me a new pair. Wondering if I should buy the new pair at walmart, or go back with interstates...
'15 27fb Signature
Atwood G6A-7E smelling gas. RuneM46 LP Gas, Piping, Tanks & Regulators 1 12-29-2014 07:20 PM
Day 3 looking and smelling better MrJim 1969 - 1973 Safari 5 09-20-2013 09:05 PM
Smelling the heat! Luftnoggin Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-18-2011 10:55 PM
How to keep the Refrigerator sweet smelling when not in use Airperson Refrigerators 7 09-11-2011 06:36 PM
