Old 03-26-2010, 12:00 PM   #1
1972 27' Overlander
Painesville Twp , Ohio
I want to make it safe
Hello all, I have a 72 Overlander. I bought it last year and haven't used the propane yet. I got the valves on the 30# tanks updated. Now I need to tackle the regulator and the lines.
I think I'll be okay if I get a regulator for twin tanks with auto switch-over. I've seen some descriptions that say "high-flow" or "low-flow". What do I need?
I also want to replace the lines shown in the picture. I think I can just get (2) 24" pigtail lines for the tank to the regulator. I'm concerned about the third line. Currently is it a mix of copper, and some flexible metal. Can this be changed out with a longer rubber line? What will the fitting size be? Is is a standard size, or will I run into trouble if I order something from a web-site?
And after all that is complete I'll start to test the lines for leaks.
Does anyone use a gas detector inside their camper?
Any other tips/suggestions are helpful.
Nick
ID:	98829   Click image for larger version
hagnik is offline   Reply With Quote
Old 03-26-2010, 12:24 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
To answer 1 question,I don`t like the auto switch,I want to know when the first tank runs out,if you plan on cold weather camper,maybe the auto switch would be good ,just check it to see if it has switched often.Don`t have any of my trailers here right now,so I don`t have the size of the low pressure line,if you take it to an RV store or propane refill store ,I would think they could get you a hose to replace your mess. Dave
easyride is offline   Reply With Quote
Old 03-26-2010, 12:33 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have a propane detector, a CO detector and a smoke detector installed inside.
Old 03-26-2010, 01:09 PM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Originally Posted by lumatic View Post
i have a propane detector, a co detector and a smoke detector installed inside.
ditto
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-26-2010, 01:26 PM   #5
1972 27' Overlander
Thanks for the feedback. Can I replace that copper/flexible metal hose with a rubber one? I don't see why not.
Nick
Old 03-26-2010, 01:27 PM   #6
Ag&Au's Avatar
Port Orchard , Washington
Just to show there are two sides to every coin. I like the auto switch. It is just necessary to look at it every day. I like the fact that nothing is interrupted when it switches over.
Regards,
Ken
Old 03-26-2010, 01:32 PM   #7
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Regards,
Ken
I am going to jump in withe Ken here. I have always had the auto-switching regulators and they have always worked great.
After a while you get an idea how long a tank lasts and only have to check every few days. With the uninterrupted service, there are no pilots to relight because the propane never went out.
Vaughan
Old 03-26-2010, 01:39 PM   #8
fotochop's Avatar
1969 23' Safari
New Orleans , Louisiana
Images: 18
..I like manual switch-over, mostly because one side of mine doesn't work and I can still use the other side! (maybe the autos allow this..I don't know)...
...you definitely want at least a propane & smoke detector inside the cabin, CO/CO2 would be a big plus also, ala Lumatic...
...I don't think the flex hose should be hooked up to the regulator, can't tell from the photo but it looks like that may be hooked up to a tee..??..
...I'd highly advise purchasing a book like either the Woodall's or Trailer Life RV repair & maintenance manuals, both are full of proper procedure and how to be code compliant with your propane/electric, both VERY important for safety...
...if you're not comfortable flaring copper lines, get a plumber etc to do it for you...
fotochop is offline   Reply With Quote
Old 03-26-2010, 02:36 PM   #9
easyride's Avatar
1977 27' Overlander
Naples , Florida
The low pressure line is the one from the regulator to the trailer,and is rubber on both my Overlanders,that allows the regulator to move when changing tanks. Dave
Old 03-26-2010, 04:24 PM   #10
1983 34' Excella
1967 24' Tradewind
Images: 32
They do. They have to work that way or you couldn't unhook a tank to refill it.
Agreed.
Vaughan
Original 2 prong cord, how do I make it safe? Jabba Electrical - Systems, Generators, Batteries & Solar 21 07-12-2010 03:01 PM
Will I be safe? cclarkego Tow Vehicles 25 08-02-2009 06:58 PM
Is It Safe?? ROBERT CROSS Batteries, Univolts, Converters & Inverters 5 12-02-2007 08:25 PM
How Safe is 53flyingcloud Off Topic Forum 18 07-31-2003 04:11 PM
