Old 08-10-2008, 07:31 AM   #1
Jephellis's Avatar
1959 18' "Footer"
Carbondale , Colorado
Images: 48
How's this so far? ('59 18'er)
We just cleaned up the stove and re-installed in the cabinet. I ran 3/8" soft copper through the belly and hooked it to the shut-off in the cabinet. At the belly I connected the stove 3/8" to a Tee that takes 1/2" to the tanks and capped one 3/8" for future fridge hook up. I ran the 1/2" pipe and attached to the belly, one spot I got attachment to the frame.
Will I regret not protecting the copper with something? Should I ground the copper to the frame somehow?
Haven't yet hooked to tanks to test for leaks, still need regulator / pigtail setup. Just wanted to get some eyes on to see if ya'll think I didn't screw up too bad yet???
Jeph
ID:	65398   Click image for larger version
Jephellis is offline   Reply With Quote
Old 08-10-2008, 08:07 AM   #2
1977 31' Excella 500
plano , Texas
Clearance change
If it were me, I would do one slight change. The line from the "T" to the stove. I would place a 90 degree bend in this line a few inches from the T. This would allow the T to be flat against the belly skin and not hang down. I can invision all sorts of road debris snagging the T since it is the lowest point. As for covering/shielding the copper, my trailer has the factory copper running under the trailer w/o any shielding and it is fine.
-thomas
tschat is offline   Reply With Quote
Old 08-10-2008, 04:47 PM   #3
Jephellis's Avatar
1959 18' "Footer"
Images: 48
Thanks Thomas! I had a similar concern. Maybe if I have enough slack in the line I can pull the pipe down and with a pipe bender put a 90 like you said....
Thanks!
Jeph
How's Your Slideout? TinShack Slide Out model 65 12-26-2015 03:53 PM
Seal seams, then polish? (59 18'er) Jephellis Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 07-29-2008 03:46 AM
59 18'er Cabinet refurb Jephellis General Interior Topics 1 07-13-2008 10:09 PM
Need help w/ Re-plumbing sink in '59 18'er Jephellis Plumbing - Systems & Fixtures 2 07-08-2008 08:30 AM
How's I-81 Over59 On The Road... 10 05-15-2004 08:03 PM
