Old 10-13-2016, 07:53 PM   #1
1954 25' Cruiser
Upstate SC , South Carolina
How What Where? Adding tanks to a 1954
We need advice on adding tanks to our 54' Cruiser. It was a park model without tanks. We are removing the floor and will begin work on the the frame next. What tanks do we need to add? What size? Will the frame need more support to hold the tanks?
Thank you in advance.
cbawin is offline   Reply With Quote
Old 12-16-2016, 10:10 AM   #2
Cruiser6483's Avatar
1954 25' Cruiser
Bern - Thun , Berner Oberland
Images: 31
Tank...
I see that no one has answered. It is really difficult to give you a tip because of tank size. Has it already a toilet or do you want to install one? The gray water simply went through the ground? You can make a smaller tank above the axle, by no means front or rear. Toilet with cassette system as in "normal" caravan is also possible. Everything else takes place and above all it brings weight!
Greetings from Switzerland - Werner
Cruiser6483 is offline   Reply With Quote
Old 12-16-2016, 11:23 AM   #3
1966 22' Safari
Fredericksburg , Texas
There's a lot to consider. We're renovating a 55 FC and at the stage in the chassis rework where I'll be adding gray water tanks in the next few weeks. We have 4" frame members so I will have two 16 gal tanks in the belly pan. We will be installing a composting toilet. Our fresh water tank will be in the original location up front above the floor. The below floor tanks will have strapping for support. Our considerations have come from threads like Dflores and MattB among many others. We currently use our 66 and know our comfort level in tank capacity. Good luck.
Bubba L is offline   Reply With Quote
Old 12-16-2016, 11:48 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We added tanks to our '56 park model...I have "How, What & Where" details in our "It's a Girl!!!" thread. This may help your design yours...
Shari
Old 12-16-2016, 01:50 PM   #5
1955 30' Liner Commodore Vanderbilt
Linden , Michigan
1954 Safari Tanks
We just removed the underhung tanks that were an add on to our 1954 Safari. I hated that look. It consisted of two large tanks, one fresh water and one combo Black & Gray.
Instead, we added a fresh water tank under the side dinette seat, a black water tank under the front toilet which was raised above the floor with a shorter stool, and a gray water tank which consisted of plumbed back and forth pipes within the frame hidden by the belly pan to accommodated gray water. I will use a blue boy when needed or other means since there is no shower producing gray, just a sink.
StevieB is offline   Reply With Quote
Old 12-17-2016, 04:07 AM   #6
1954 25' Cruiser
Images: 31
Do It Yourself
(for my Notin 1959)
Adding a second battery in the stock location behind the propane tanks.... drboyd Batteries, Univolts, Converters & Inverters 4 06-12-2014 04:23 PM
20lb tanks vs 30lb tanks? AldeanFan LP Gas, Piping, Tanks & Regulators 5 04-05-2014 12:37 PM
'Convert' from 30# tanks to 40# tanks HeavyAssault LP Gas, Piping, Tanks & Regulators 19 11-28-2013 11:42 AM
LP Gas Tanks: Replacing 20# with 30# tanks? Pete Vermont LP Gas, Piping, Tanks & Regulators 28 01-30-2008 08:34 AM
Adding tanks to 55... Sizes Needed cloud55 Waste Systems, Tanks & Totes 2 02-28-2006 08:49 AM
