Old 08-11-2010, 09:46 AM   #1
Winnipeg , Manitoba
How to use my detector
My detector has 2 lights, in the picture they are to the left under the test button. The top one has 3 colors, green, yellow, and red for normal, fault, and alarm. The bottom one says valve, and has recently turned on and blinks occasionally. I'm not sure what this means. But I did turn off the tank till I get it figured out. Can anybody help me out?
Tagalong is offline   Reply With Quote
Old 08-11-2010, 09:56 AM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The detector is set up to operate a solenoid valve. Motorhomes of some eras had a propane shutoff valve held closed by a spring and opened by a solenoid connected to the propane detector. The idea was that, if the propane detector tripped, or was disconnected, the gas supply would be shut off. I don't think they were ever used on trailers in the U.S. but maybe they were, or still are, in Canada. Or maybe someone put in a propane detector with the extra circuit and there isn't a valve connected to it.
There were two problems with that approach. One, the solenoid valve requires enough electricity to hold open to pose a fairly serious problem for boondocking. Two, propane leaks into the living quarters of RVs have never been a notable cause of fires.
The solenoid valve setup is still used for marine applications, where propane fires and explosions have been a much more serious problem, and where battery operation for days at a time is highly unusual.
Installing a LP detector Dieselgrin General Interior Topics 11 01-07-2009 07:42 AM
LP Gas Detector - 2005 Classic Stream 1529 2001 - 2005 Classic 2 06-15-2006 06:44 AM
Lp Detector davidz71 LP Gas, Piping, Tanks & Regulators 7 12-12-2005 09:44 AM
Lp Detector PARKS1963 LP Gas, Piping, Tanks & Regulators 3 09-15-2005 08:37 PM
Gas Detector winner Airstream Motorhome Forums 2 07-02-2002 03:59 PM
