Old 12-15-2014, 03:32 PM   #1
2000 30' Excella
Monticello , Florida
How to safely remove gas stove ?
I have gutted most of my AS and want to remove the gas stove/oven from 2000 Excella. Where is the best spot to cut off the supply of gas?
07007 is offline   Reply With Quote
Old 12-15-2014, 04:07 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Just turn off the bottles.
I don not think there is a local shut off behind the stove so the whole system ha to be shut off
2004 Excursion 4x4
Old 12-15-2014, 04:09 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
There should be a disconnect underneath the trailer, I would turn that off and remove the line from there up to the stove. Then remove the stove... I am basing this on the assumption that you are doing away with the stove?
Aaron
WBCCI #XXXX AIR #2495
Old 12-15-2014, 04:11 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Safest way is, light the burners. Then go outside and shut the propane off at the cylinders. The burners will burn off any residual propane in the lines and then go out by themselves.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-16-2014, 07:23 AM   #5
2000 30' Excella
Good ideas�� I will replace burners with induction plates and oven with micro/convection unit.
Old 12-16-2014, 07:53 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
When you have the induction plates installed I would like to see a photo of the install.
Are you going to upgrade the electrical to 50A 220v? At ~1800 watts each, two induction plates would not work on the 30A 120v service, even if everything else was off.
Alan
Old 12-16-2014, 08:35 AM   #7
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
There should be a shutoff valve under the trailer. In addition shutting that valve and removing the line to the stove, you should install a threaded cap and test it with soap bubbles to make sure it is gas tight.
BambiTex is offline   Reply With Quote
Old 12-16-2014, 11:01 AM   #8
2000 30' Excella
Thanks Alan, I guess I'll just use the one plate that draws 1800 watts and replace the top burners with a two burner has stove top and micro under
Old 12-16-2014, 11:40 AM   #9
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
There may or may not be a shutoff under the trailer. I don't know about the new ones. Mine had a shutoff right where it entered the inside of the stove itself. You can put in a cap like listed above to ensure it's gas tight. Use the yellow teflon tape - made for propane. Easiest way is to use tin snips to cut it. Flatten, then cut.
Rob.
robwok is offline   Reply With Quote
Old 12-16-2014, 11:53 AM   #10
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
NO HOOKUPS? Power Outages?
I've been in campgrounds with full hookups where the power has gone out for hours, and every time I travel, the need for a cup of coffee always strikes 100 miles from any decent coffee shop.
I think you're wise to choose a 2 burner propane hob. I'd forgo expensive installed induction plates. Save your counter space. I fell for those infomercial Nu-Wave Induction burners (2 for $100 - just resist most or all of the "pay the shipping only" crap) and gotta tell you they are great. Better than installed because you can use them outside too. Fondue anyone? Get a hob with a glass cover, and set the induction burner on top of it (they don't like being put on a metal surface). Best thing? Timer as an alarm clock. At 7:00 my kettle starts to sing and I reluctantly crawl out of bed.
Having a 2 burner stovetop (hob) that uses propane is handy when traveling or when the power goes out. Burners aren't safe to heat the trailer... but if it's just chilly a cup of hot soup or tea really helps. Without electricity most furnaces won't operate, but even a Honda 1000 and a heavy duty extension cord can run a space heater or a Dyson HOT/Cold fan. Not comfy, but warm enough to keep the pipes from freezing. Long johns - ugly but functional!
Paula
Old 12-17-2014, 11:00 AM   #11
2000 30' Excella
Paula
I like your style��
Need to Safely Remove Exterior Door--1998 Excella gquake Doors & Locks 1 06-24-2014 06:29 PM
not sure how to remove this safely? s.s.sloan Clearcoat, Exterior Paint & Trim 6 11-09-2007 10:04 PM
How can I safely purchase Airstream online? sukiandmarc Buyer Guidelines 14 01-21-2006 09:45 PM
How much can I safely tow with my 99 Lincoln Navigator? tslanier Tow Vehicles 9 11-06-2005 06:14 PM
Which A/S can we tow safely with our Toyota? silvernewbie Tow Vehicles 15 03-01-2004 07:53 PM
