Old 10-10-2014, 01:54 PM   #1
1959 24' Tradewind
Excelsior , Minnesota
How to hang gas line under rv and when to paste before or after hanging
Hi, I'm going with black pipe and have about four sections should I put the dope on and seal before or after I hang the pieces, I'm afraid that if I do it before they will leak from movement to get it up etc. but if I do it when connected to the underside it will be difficult to make turns and get all of the fitting lined up correctly underneath. Hope this makes sense and I'm going with a paste and not yellow tape since I've read here that it seems to be the new standard. Also do I need to put hose between hangers and pipe and underside aluminum?
Love you all and hope to God that I leave my driveway in this thing one day!
betsy is offline   Reply With Quote
Old 10-10-2014, 02:14 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Dope is the preferred method for black pipe. You are working with low pressure gas so it is unlikely you will move a given joint while placing the system up under the trailer so dope before.
How are you going up into the trailer? Flared copper is the correct method.
2004 Excursion 4x4
Old 10-10-2014, 02:20 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
FWIW my trailer is plumbed with copper LP lines. they are put together with flare fittings and are held to the underside of the belly with rubber lined p-clamps.
Aaron
WBCCI #XXXX AIR #2495
Old 10-10-2014, 02:20 PM   #4
1981 31' Excella II
New Market , Alabama
Black pipe would not be my first choice. I would go with copper. Black pipe is expensive and heavy. Also joints are more prone to leak than flared copper. I prefer Teflon tape for pipe joints. I have never been able to get paste to seal. If Teflon tape is used properly it won't leak at all.
Perry
Old 10-10-2014, 03:51 PM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I believe RVIA code calls for copper, because it will flex as your trailer flexes. As for hanging it, the bare minimum is one hanger at each joint or each change in direction of the tubing if you bend the tubing to form elbows.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-10-2014, 04:04 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
RVIA Code doesn't specify, only that joints be accessible for inspection. I have seen black pipe, copper as well as rubber hoses used for plumbing the LP systems. Look under some of the new SOB's and you will see that they are using rubber hoses with fittings attached with zip ties.
I am old school and my first choice is going to be copper.
Aaron
Old 10-10-2014, 04:40 PM   #7
Lets travel's Avatar
2014 30' Classic
Fayetteville , North Carolina
I would not use black pipe to much vibration, copper would be much better.
Lets travel is offline   Reply With Quote
Old 10-10-2014, 05:30 PM   #8
Central , Mississippi
My '63 had the main manifold run with black, copper ran up and into the shell. I went back with all copper, it was much easier in my opinion.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-10-2014, 05:44 PM   #9
1981 31' Excella II
The black iron pipe of today is made in China and tends to be porous.
Perry
Old 10-10-2014, 07:06 PM   #10
r carl's Avatar
Lin , Ne
Perry
Just like their tires.
Old 10-10-2014, 07:34 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
When I had to make a repair, I used flexible copper and flare type brass compression fittings. I slid each piece of the copper pipe inside a slightly shorter length of PEX pipe before making the flare, so that the PEX would act to protect the copper from road debris. This way the flare fittings are accessible and there is no wear on the copper pipe from the hangers.
I used this type of hanger, slightly larger than the diameter of the PEX.
add edit:
If you decide to use the black iron pipe, don't forget to use a dielectric adapter fitting at every location where iron transitions to brass/copper. If you do not use these fittings, galvanic action will corrode the pipe quickly. These fittings just slow the process down. There will still be corrosion at these dissimilar fittings.
Alan
Old 10-11-2014, 06:29 AM   #12
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
I went straight copper, flair fittings, all the way. It held up for 40 years, and I'll be dead before another 40 rolls around...
-Red
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 10-11-2014, 08:23 AM   #13
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I needed a 3/4" supply line to run my on demand hot water heater, so I used black pipe secured about every foot.
I built it in place with pipe dope.
Paste vs Bars? steveirving Cleaning, Stripping & Polishing 4 04-09-2014 04:29 PM
70s Wallpaper Paste BrockLives Upholstery, Blinds, Walls & Interior Finishes 1 08-28-2009 08:15 AM
Before and After, and a question about mattresses pageclot Upholstery, Blinds, Walls & Interior Finishes 9 03-22-2009 04:01 PM
photo paste try Ladi Holovsky All Argosy Trailers 2 08-11-2003 10:23 AM
Before and After ALANSD Upholstery, Blinds, Walls & Interior Finishes 4 03-24-2002 02:52 PM
