Old 07-02-2013, 02:25 PM   #1
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
How often to inspect Propane tanks?
I was getting my tanks refilled and the attendant couldn't find an up to date inspection mark. This was news to me...he filled them but suggested I visit my local welding shop to have the tanks inspected...said it was required every 5 years? Really?
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 07-02-2013, 02:28 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
From the TX Railroad Commission site: "Each cylinder must be requalified for continued use when 12 years have elapsed from the cylinder’s date of manufacture. External visual inspection is required for an additional 5 years requalification period."
David
DKB_SATX is online now   Reply With Quote
Old 07-02-2013, 02:30 PM   #3
3campers's Avatar
1985 31' Limited
Images: 18
Huh...where does one get that inspection?
1985 31' Limited
Old 07-02-2013, 02:49 PM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
I got the same grief for the first time in two years at a Flying J from a young attendant trying to "follow the rules" because my tanks date from the trailer birthday, April 1999, even though they have had the new valves installed on them...so, I too would like to know where to go to get these certified or fixed???
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-02-2013, 03:07 PM   #5
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I had 15 year old aluminum tanks certified by our local county residential/commercial propane supplier.
They put in the new valves and stamped an inspection date on the collor.
I think it took about 20 minutes for the 2 tanks.
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 07-02-2013, 03:17 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
There's a list for TX of places to get cylinders recertified... it seems like most large-scale propane suppliers provide the service here. I would think that if a large local propane dealer didn't offer the recertification, they'd know who does.
David
Old 07-02-2013, 04:39 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Some of the cylinder manufacturers use a really thick paint that tends to obscure the original stamped markings on the collar. Sometimes holding it in various angles from the sun helps to reveal the stamped numbers/letters. And sometimes not, in which case I just use good sense: If the cylinder looks newish and is good shape, I fill it.
New cylinders are good for 12 years after initial certification at the factory in the USA. Canada's laws differ, I believe.
If the cylinder has already been recertified in the US, the markings are pretty easy to spot. Some recertifiers use stamped markings; others use a robust label. In any event, for a visually recertified cylinder, it'll have an "E" (think "eye") before or after the month/year date on which the recert took place. The cylinder is good for five years after that date. You can have it recertified indefinitely, as long as the cylinder is in good condition and no new laws prevent the recert.
Oh, final note. In the US, states -- not the federal government -- control propane handling, installation, filling, cylinder recert, and the like; laws governing these vary quite a bit from state to state, but most adhere at some level to the recommendations made by the NFPA. (DOT and ASME set forth design characteristics for cylinder manufacture.)
Lynn
WBCCI 21043
