Old 08-05-2014, 10:16 PM   #1
alumascoupe's Avatar
1966 26' Overlander
Frozen , Tundra
How many gas valves ?
Hi all, my overlander had only 1 gas shut-off valve located inside the trailer just before the furnace. I see other posts mention shut offs under the trailer, and additional shutoffs at other appliances such as the water heater. My question is, how many valves should I have, and where ?
alumascoupe is offline   Reply With Quote
Old 08-05-2014, 10:23 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '74 Argosy has shut off valves for all appliances. The furnace; the cook stove; and water heater are all outside under the coach. The refer shut off is operated from inside, but the valve is outside. It is located behind the access hatch.
Old 08-06-2014, 01:14 AM   #3
1966 26' Overlander
Frozen , Tundra
Probably by the 70's safety was a bigger thing ? Any 60s owners still have original gas plumbing ? I think its odd the only valve on my AS is located inside ! I get why valves outside are probably safer, but what is the reason behind so many valves? Is it so if one appliance develops a leak you can shut it down and finish the trip with the others operational ?
Old 08-06-2014, 04:15 AM   #4
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
On our 1980 International, we have one for the furnace, one for the water heater, one for the range, one for the fridge and one additional mystery one. Not sure if there are separate ones for the oven and the stove top, but hoping to figure it out this weekend!
Rhino33 is offline   Reply With Quote
Old 08-06-2014, 01:54 PM   #5
1981 31' Excella II
New Market , Alabama
I don't see why you need any valves. Best to turn off the propane and vent the system prior to removing anything. Unless you have a need to remove one appliance and still run the others. I see no reason for it from a safety standpoint.
Perry
Old 08-06-2014, 03:13 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
My 2010 doesn't have any gas valves, other than the ones built into appliances and the ones at the tanks.
The only real advantage of valves for each appliance is that it would allow you to operate all the working appliances if one developed a leak while traveling. That's pretty rare, though, and you can accomplish the same thing by carrying a flare cap of the proper size.
Old 08-06-2014, 03:21 PM   #7
Thalweg's Avatar
1962 24' Tradewind
Buffalo , Wyoming
My '62, with mostly original gas lines, has a valve for every appliance. Stove, water heater, and fridge are at the appliance. The furnace valve is under the trailer because there is no easy access to the gas connection on the furnace itself.
Thalweg is offline   Reply With Quote
Old 08-07-2014, 03:06 AM   #8
1966 26' Overlander
Frozen , Tundra
Well, looks like maybe AS is a bit eclectic in their gas valve placement and usage. I think for now I'll just stick to the original design and have the one valve inside just before the furnace, it never blew up in the first 48 years so whats the worst that can happen ? Jammer, I like your cap idea, my travel tool box will contain one of each size when the Overlander lives up to its name again ( They come apart so quickly, but when it come to assembly...)
Can old LP tank valves be upgraded to OPD valves? jimblacker LP Gas, Piping, Tanks & Regulators 8 03-26-2014 06:07 AM
Too many valves? Water Heater rogowolf Water Heaters, Filters & Pumps 4 01-28-2014 11:42 AM
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
How many low point drain valves on '08 23FB? bonginator Plumbing - Systems & Fixtures 6 10-01-2012 07:42 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
