Old 05-09-2016, 12:02 PM   #15
dino84ac
1992 29' Excella
Fort Davis , Texas
Has anyone poured water over a tank to find the propane level? I have & it works. The propane chills the water forming a light frost.
dino84ac is offline   Reply With Quote
Old 05-09-2016, 12:20 PM   #16
richw46's Avatar
Lexington , Kentucky
I have the LP tank cover over mine, I think I'd have to remove that to see the level. I think that the propane will get cold only if it's in use, gas is leaving the tank, like when the furnace is running. Is that when you are able to see it?
I just use one tank at a time, running it to empty then switching to the other. As soon as one is empty I take it to get filled unless we're getting ready for a long trip, then I'll fill it again when we arrive. That seems to work best for us, I never worry about running out.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-09-2016, 02:19 PM   #17
2011 27 FB International
Vancouver , British Columbia
Full time currently on full hookup, so fridge runs on 120ac. We use the hot water (generally off when not needed), furnace (when necessary) and cooking.
We only need the furnace when our electric heater cannot keep up (generally below 50F). Using the electric did help to significantly reduce the furnace usage when colder.
At the coldest in the winter in Vancouver (20F for a short spell, generally just above 32F at night and in the 40s in the day) a tank lasted one week on average. We did skirt for the coldest months which helped a lot with floor temperature but didn't seem to make a big difference on propane usage.
In warmer months a tank is lasting a month. The last refill was 3 weeks, I expect from here out it will be 4-5 weeks each time.
I periodically check the indicator that tells if a tank is empty (but not how much propane is in the tank) and refill the empty.
mixedpuppy is offline   Reply With Quote
Old 05-09-2016, 02:29 PM   #18
CruizinDux's Avatar
Eugene (Tracktown USA) , Oregon
Originally Posted by richw46 View Post
...... We had the fridge on during the entire trip. In camp it was on AC, traveling, it was on propane.
When cylinder 1 went empty (the water heater light comes on, stays on) I switched to cylinder 2 and took cylinder 1 to get it refilled. Eventually cylinder 2 emptied and I switched back to cylinder 1, filled cylinder 2. At the end of our trip I was back on cylinder 2 for a couple of weeks, cylinder 1 is empty.
Rich, can you clarify. You're in camp and on AC. The WH is switched to Ele (on our 20, we have dual switches in the bathroom, 1 for gas and 1 for ele and the light goes out after ignition). Are you saying that when hooked to AC and heating water with AC, that when you run out of propane due to heater usage or whatever, that the light in the BR turns on and stays on?
I also like your idea of not topping off tanks before a trip to save in hitch weight. Propane is so available I can't see the need for having two full tanks while on the road.
On our maiden voyage in Jan/Feb from Eugene to San Diego...we used about a tank and a half, but ran the heat a lot. I was originally thinking the regulator would switch over, but now understand it the color that switches, the lever switch is manual.
CruizinDux is online now   Reply With Quote
Old 05-09-2016, 02:36 PM   #19
CruizinDux's Avatar
Originally Posted by FCStreamer View Post
So my AS has two 30 lb propane tanks and no gauges. I am assuming that this is setup so that when one runs out, you use the 2nd one while you refill the first.
How do you know you ran out of propane? I assume when you have no more hot water?
If I use propane to run the fridge only, for example, how long will a 30 lb tank run? Are we talking 1 day? 1 week? 1 month?
FCStreamer, I tend to save links by category that I think I'll refer to later as opposed to the AS search function.
Here are some threads I had saved and you may find useful. I'm color blind and I think I'm going with the 2 gauges in....KISS
http://www.airforums.com/forums/f287...ne-149801.html
offered by TN Traveler on post # 12
http://www.airforums.com/forums/f287...-145711-3.html
http://www.airforums.com/forums/f287...ty-109554.html
http://www.airforums.com/forums/f287...on-149824.html
Old 05-09-2016, 02:43 PM   #20
richw46's Avatar
My water heater is not electric, just propane. We turn it off at night. When the propane tank is empty the ignition light just stays on because it didn't light the propane because the tank was empty. Switch over to the other tank and flip the switch, light goes out, water heater kicks on. I never keep the propane switch on both, just one tank or the other.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 05-09-2016, 03:38 PM   #21
The regulator does automatically switch (or at least mine does). The lever points to the "primary" tank. Once the primary is empty the regulator switches to the secondary tank, but the lever remains pointing at the empty tank. Unless the secondary is empty you should see no disruption to your propane use when that happens. To refill, change the lever to point to the secondary tank, which then becomes the primary tank. Disconnect the empty secondary tank, refill, repeat.
Old 05-09-2016, 03:51 PM   #22
1996 25' Excella
Tillsonburg , Ontario
Easiest way to check propane tank level is to pour hot water over a small section of tank wall
Tank wall in Gas space will be hot
Propane level will feel cold
Try it
JCW
JCWDCW is offline   Reply With Quote
Old 05-09-2016, 07:31 PM   #23
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
Originally Posted by greghoro View Post
For more accurate tracking without a gauge, you may want to consider purchasing an inexpensive hand held luggage scale. Get one which has a second sweep hand which retains the measured weight, so you don't have to look at the scale when you are lifting. Note, you will have to be able to lift 56 lbs.
Here is a simple chart:
Full - 56 lb
3/4 - 48 lb
2/3 - 46 lb
1/2 - 41 lb
1/3 - 36 lb
1/4 - 33 lb
Empty - 26 lb
Greg
______________________
Is this with a steel tank or an aluminum one?
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 05-09-2016, 08:09 PM   #24
CruizinDux's Avatar
Rich, thanks. It sounded too easy but makes perfect sense with a propane only WH.
Old 05-09-2016, 08:48 PM   #25
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I pretty much only use the propane for cooking and the refrigerator when on the road. Seldom if ever use it for the furnace. I get close to 6 months or more on 1 tank.
TinCan
graysailor is offline   Reply With Quote
Old 05-09-2016, 09:31 PM   #26
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
On the road for 4 weeks thru Northern California , up the Oregon coast and back to Billings , 4 1/2 weeks used 1 tank propane.....
Old 05-09-2016, 10:28 PM   #27
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Steel
I believe an equivalent 30 lb aluminum tank weighs about 8 lbs less.
Greg
greghoro is offline   Reply With Quote
Old 05-10-2016, 05:06 AM   #28
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Any propane tank should have the "tare weight" (often abbreviated TW) stamped on the top of the tank. Anything above that weight should be propane.
The people who fill the tanks use this to tell when the tank is full. They set the tank on a scale and fill until it reaches the proper weight (TW + 30# for mine).
How Long Does A Battery Last? ElCamino Man Batteries, Univolts, Converters & Inverters 9 09-07-2012 05:09 PM
Anyone towing 27FB (7,600 lbs / 770 lbs tongue) with a V8 or TDI Touareg ? Timofeevich Tow Vehicles 41 09-23-2011 05:55 PM
How long does a polish last? Dureedesign Cleaning, Stripping & Polishing 2 05-04-2007 07:17 PM
long bed vs short bed towing 8400 lbs. longears Tow Vehicles 24 08-09-2004 03:32 PM
