Old 03-25-2014, 07:09 PM   #1
1968 28' Ambassador
Ojai , California
How do I find and repair leak in propane lines?
In my 68 Ambassador, a check was run on the propane system and it took about 2 minutes to lose pressure, which means there is a leak. I was told that it should hold pressure for at least 3 minutes, and preferably 5 minutes.
I see that the lines run under the body of the chassis.
Has anyone else had a lead repaired? Is it costly, a nightmare, etc?
Is this something I can fix myself (not a mechanic), or can an RV shop or specialist fix this easily?
Thanks! Jim
jimblacker is offline   Reply With Quote
Old 03-25-2014, 07:14 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Jim,
Apply soapy water to the fittings and lines, the leak will bubble. If a fitting leaks, try tightening, if the line leaks, replace. You will also need to follow the lines into the trailer to the appliances. There may be shut off valves where the line goes to the appliance, if so, shut them off before searching for the leak then turn them on one at a time.
Bill
Thanks! Jim
Just my personal opinion
Old 03-25-2014, 07:28 PM   #3
1987 25' Sovereign
Oregon , Ohio
For 35 years I repaired leaks on natural gas lines in Ohio. Preferably there should be no pressure drop at all, no matter how long. Propane is heaver than air and will settle to low spots and accumulate. Evan though you see lines under your trailer, they go into feed the furnace, stove and hot water tank. The best way for you to test the lines is to get a spray bottle and use soapy water to spray all the fittings with the lines pressurized. The soapy water will bubble where there is a leak. Start at the propane bottles and work your way back. It is most likely a fitting that is loose and can be tightened, if not than you will have to soap down all of the copper lines to check for bubbles. You will need to do this outside where it is well ventilated if you are using the propane to pressurize the lines
msmcv51 is offline   Reply With Quote
Old 03-25-2014, 08:02 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
You don't have a leak you have a hole. Pressure dropping that fast you would be smelling it. Did you see the pressure drop that fast or is a dealer telling you this. I ask this because the description of a 2 1/2 minuite test is a farce. The system should hold pressure once pressurized and the tanks turned off for weeks
Is it possible that the oven pilot is on? If so you will smell gas if you open the door after the gas is on for a minute.
When you start with the soapy water start right at the tank valve and if equipped at the gauge. Soap everything.
2004 Excursion 4x4
Old 03-25-2014, 08:24 PM   #5
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Start with the easy stuff make sure ALL stove and oven knobs are "fully" off it is easy to leave the oven on the pilot if all fully off then get out the soapy spray and do as above recommend.
Garry
Old 03-25-2014, 11:19 PM   #6
1988 Argosy 32
Lomita , California
2 tanks ? how old is the ruber hoses from tank to regulator, i use 409 spray it makes Big bubles.
I found that my stove had a small pilot light for the top 4 burners that had to be relit every tine the gas was turned off & on, (yes that is a leak) thank you attwood.
My fix was a 1/8 pipe plug, and we now use a bbq spark lighter.
Wolfe is offline   Reply With Quote
Old 03-25-2014, 11:41 PM   #7
1968 28' Ambassador
Ojai , California
Thank you all for the responses! Much appreciated!
Much appreciated!
Can not find Propane leak bmklawt LP Gas, Piping, Tanks & Regulators 15 01-02-2011 10:01 AM
Running propane lines Safari Tim LP Gas, Piping, Tanks & Regulators 7 07-01-2007 03:45 PM
propane lines airtim LP Gas, Piping, Tanks & Regulators 18 03-26-2005 07:38 AM
Bleed lines after propane refill!!! Astrodokk On The Road... 4 12-01-2003 11:08 PM
