Old 01-15-2007, 09:38 PM   #1
1967-Caravel's Avatar
1967 17' Caravel
East Bernard , Texas
Hot water heater (ugly sooty yellow flame)
I have a 67' Caravel trailer. It has a 6 gallon Atwood hot water heater. The guy I bought it from said it has really never been used since put in new in 1999. After buying this trailer last week I have slowly been tinkering with things. Yesterday I got the pilot light to start and stay lit, but when you turn the gas to the "on" position the burner comes on and lights but it puts out a long ugly yellow flame with a lot of black soot. It is not a nice continouous burning blue flame like I'm thinking it should be. Does the burner need to just be cleaned from this thing sitting or what could it be? Dont wan't to try 100 different things if somone can narrow it down for me........thanks.
Steven
"he who dies with the most toys wins"
1967-Caravel is offline   Reply With Quote
Old 01-15-2007, 09:39 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
A good cleaning and adjustment sounds like a great first two steps.
Old 01-15-2007, 09:46 PM   #3
1967 17' Caravel
I saw some screws on the regulator that say Vent, pilot, etc.........I guess I can just turn those and adjust to see if I get a better flame.
Steven
Old 01-15-2007, 09:49 PM   #4
Aluminut
2004 25' Safari
. , Illinois
Yes, you are right on. What you describe sounds like the air/fuel adujuster. After cleaning the feed tube, adjust that trap door looking thingie (yes, that's the technical term ) and see if that helps.
One other note is to make sure the exhaust is clear and there there are no nests.....that would be my last rabbit in the hat before you'd need to call in the heavy hitters here to help.
Old 01-15-2007, 10:57 PM   #5
1960 24' Tradewind
santa barbara , California
alot of the time you get spider web inside the small openings that cause disruption in the flame .Id blow out the burner tube and other parts to clear
it .most likely that will get it going .
Scott
scottanlily is offline   Reply With Quote
Old 01-16-2007, 05:23 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
There is a mix tube before the outlet for the burner. Look for a slotted piece of pipe with a screw in one of the slots. Loosen the screw slightly, and slide the mix tubearound until you get a nice blue flame. This is after you clean our the mud dauber nest or spider web that is likely blocking it...
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 02:29 PM
Water Heater Woes airstreamcaravel Water Heaters, Filters & Pumps 3 09-07-2005 09:18 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
travelling w/out water system maznblu Fresh Water Systems 6 09-09-2002 12:03 PM
