Old 08-19-2014, 07:37 PM   #1
1969 23' Safari
fairfield , Pennsylvania
hot water heater problems!!
problem when I first fired it up(Manuel light) the pilot light stayed on an when I turned to on
I worked fine. There was hot water in the kitchen but only a few seconds of hot in the bathroom, then it went cold.now when I try to light it the pilot light won't stay on and there is no fire. Anybody have any ideas.could there be a leak? Plenty of fuel
russellsue is offline   Reply With Quote
Old 08-19-2014, 08:26 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Check your bypass valves on the back of the water heater.
Old 08-20-2014, 07:44 AM   #3
1969 23' Safari
hot water beater problems
Plenty.of flow valve. Is.on the. Use position. Stove works fine piolet light still
still won't stay on Could the regulator be bad?
Old 08-20-2014, 07:56 AM   #4
Missouri Valley , Iowa
Could be the regulator but if the stove is working properly, the problem may be the thermocouple for the water heater
Dan
Farmer Dan is offline   Reply With Quote
Old 08-20-2014, 08:03 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would remove the pilot tube from the gas valve. Hold the pilot valve down fro a few seconds to test for gas flow from the valve. If you have gas the remove the pilot tube and make sure the orifice is clear. Reinstall and try again. If you do not have gas the valve may be bad.
If the pilot lights and the main gas does not fire correctly remove the burner tube and check for a spiders nest.
2004 Excursion 4x4
Old 08-20-2014, 08:22 AM   #6
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I would try cleaning the propane pilot and burner tube first and see if that works. If not...If the pilot stays lit when you hold down the button, and goes out when you release it, it's probably the thermocouple. This is the cheapest and easiest to replace. If it still doesn't work, it may be the valve.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-20-2014, 09:45 AM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We had the same symptoms during our summer trip this year. Replacing the pilot thermocouple assembly did not fix the problem. We had a new water heater installed at the factory, problem solved.
Richard
Old 08-20-2014, 10:14 AM   #8
HowieE's Avatar
Images: 12
Lets get the pilot flame lit before you question the thermocouple. All that is necessary for the pilot light to light is gas flow and a match.
If the pilot lights and after having held the valve down for 30 seconds that main flame does not come on that could be a thermocouple, bad valve or a spider nest in the burn tube. The spider is the most common.
Though stink bugs are challenging them for first place.
2004 Excursion 4x4
Old 08-20-2014, 02:16 PM   #9
1969 23' Safari
Tube clear pilot still won't stay lit where is the thermo coupler located?
Old 08-20-2014, 02:22 PM   #10
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
It's the little silver thing that sticks out into the path of the pilot flame - when there is a flame. It tells the regulator that there is a flame there so it's OK to turn on the gas when there is a demand. Usually there is a thin coil of tubing (looks like an uncoated wire) coming off the backside of it. Real easy to replace.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-20-2014, 03:05 PM   #11
HowieE's Avatar
Images: 12
The thermocouple is a small probe about 1/8 in. in dia. and 3/4 in. long that should be washed by the pilot flame. If it is in that position so the f;lame heats it and you have held the flame on for 30 seconds and the pilot flame goes out when you release the valve. Next thing to do is follow the thinner silver tube back to the valve. It is held in place with a 3/8 brass nut. Loosen the nut and remove the tube. Wipe the end of the tube with a cloth and reinstall Tighten but do not try and brake it off. That tube supplies a mill volt signal to the gas valve to show proof of flame. If cleaning and resetting does not solve the problem replacement of the thermocouple is the next step
2004 Excursion 4x4
Old 08-24-2014, 05:10 PM   #12
1969 23' Safari
I want to thank you all for your input I willget a thermocouple and see if that fixes the problem again thanks
Russ
Hot hot hot aluminum! luvoldstuff General Repair Forum 23 06-24-2013 01:08 AM
Hot water heater and water pump xo1rider 2011 - 2015 International 3 10-12-2012 06:55 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 12:24 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
