Old 07-14-2004, 11:23 AM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Horizonal Tanks
Been thinking that a single horizonal tank on the tongue would be alot less trouble than carrying around vertical tanks, taking them off and putting them back on for filling. How are the horizonal tanks filled since they stay on the trailer or MH. Are fewer fill stations available for this setup. Just giving it a look.
Over59 is offline   Reply With Quote
Old 07-14-2004, 12:08 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Horizonal Tanks
Greetings Over59!
It has been several years since I sold my Brand X trailer that had the single horizontal tank, but I wasn't terribly impressed with its functionality. It was always an issue when refilling - - some vendors insisted that it be removed from the tongue while others insisted that it had to remain on the tongue - - it definitely wasn't designed for easy removal from the tongue (this was on a 1980 Nomad Light-Weight Special 18'). Some vendors refused to refill the tank because they were unfamiliar with horizontal tanks on travel trailers. I could generally travel locally without too much difficulty once I learned which vendors would fill the tank, but long-distance excursions were turned into adventures when the LP ran low and it became necessary to find a vendor willing to refill the horizontal tank while on the road.
Beyond issues with finding a vendor to refill the tank, it didn't provide a back-up when the tank was empty you were out of gas. With the twin tank and automatic switching regulators as used on most Airstream trailers, an empty tank can easily be removed for refilling without disrupting the LP supply to the coach. This can be an important consideration when the coach is utilized when LP vendors may not be open due to holidays, when the distance to the nearest vendor may be great, or when the coach may be utilized in below freezing weather and you want to protect your coach's plumbing from freeze damage.
I would suggest checking with your local LP supplier and get his/her advice on a horizontal LP tank for your coach. If they are a common type of tank in your area it is possible that you might not encounter the refill headaches that I did with the horizontal LP tank on my Nomad.
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 07-14-2004, 12:44 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
If it is clearly a frame mounted tank then they should have no trouble filling it. All Motorhomes have frame mounted ones and I have not had any trouble getting it filled anywhere.
Kevin does bring up a good point though. You need to be more aware of the LP usage/level since you have no backup. Also in some States law requires any vehicle mounted tank to sit for 15 Min before filling. Kinda a pain if you are passing through.
Are you going for ease or a visual aesthetic? Ease of use is truly the OEM setup IMHO.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-14-2004, 10:18 PM   #4
Over59's Avatar
Images: 37
Thanks guys. Sounds like a problem on several fronts. Idea was to reduce problems. I'll be getting vertical tanks.
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 07:47 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 02:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 01:11 PM
