Old 12-09-2018, 11:32 AM   #1
2009 30' Classic
a city in west GA , Georgia
Help with this propane stamp code
Off of a 2009 classic 30'. I'm the 3rd owner . First time to fill this tank, it is aluminum. Thank youClick image for larger version
What is your reading of this expiring date?
Joyman is offline   Reply With Quote
Old 12-09-2018, 11:35 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Should be ok.. they can recertify at the propane fill station. Go to a PROPANE dealer, not Tractor Supply, etc...
Peace and Blessings..
Channing
WBCCI# 30676
Old 12-09-2018, 11:40 AM   #3
2009 30' Classic
The other original stamps i believe are original stamps on trailer
Here is a photo of these
[ATTACH]Click image for larger version
Old 12-09-2018, 12:08 PM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by joyman View Post
off of a 2009 classic 30'. I'm the 3rd owner . First time to fill this tank, it is aluminum. Thank youAttachment 329353
what is your reading of this expiring date?
11/2008
Old 12-09-2018, 12:38 PM   #5
2009 30' Classic
Thank you Terry
But was the tank recertified with the first photo?
The code that ends in CE?
Old 12-10-2018, 12:54 PM   #6
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
002212CE is the tank's serial number.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 12-10-2018, 01:19 PM   #7
harryk's Avatar
2005 31' Classic
Venice , Florida
Take your tanks for refill to a actual propane supply dealer...if the tanks need certification, they usually will do on the spot or you can pick up the next day. (Should not be expensive)
harryk is offline   Reply With Quote
Old 12-10-2018, 02:48 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
https://www.phmsa.dot.gov/sites/phms...pane_en_v3.pdf
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 12-10-2018, 02:52 PM   #9
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Your tanks are good for 12 10 years from manufacturing date (11/08 as Terry pointed out) before they require recertification. So, you're good for another 2 years, then have them recertified. Aluminum tanks that haven't been heavily damaged will last indefinitely.
I either forgot or didn't know that DOT changed this regulation in 2017.
In the US they're only good for 10 years now, which fits with a later post about Canada.
David
Old 12-10-2018, 02:59 PM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My understanding is that the tanks are only good for 10 years in Canada. Make sure you fill up before you cross the border.
Richard
Old 12-10-2018, 08:31 PM   #11
2009 30' Classic
It is a serial number. Thank you Kevin S. I wasn't sure at time. But the propane man also told me this today. He recertified it today. And current law it's goo for 10 years he said. Put a sticker on it. Thanks
Old 12-13-2018, 04:40 PM   #12
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
nice,,, how much does it cost to get recert on tanks??
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 12-13-2018, 04:49 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I thought the original certification was good for either 10 or 12 years but that it has to be rectified every 5 years thereafter? Has that been changed?
Old 12-13-2018, 08:24 PM   #14
DaveP's Avatar
2004 28' Classic
Monument , Colorado
In Colorado at Amerigas, they re-certified my aluminum tanks last year for $10 each. Drop off one day, pick then up the next day.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 12-13-2018, 08:53 PM   #15
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
A recertification is good for only five years. If passes inspection. They do not re-stamp the tank or stamp over the original date. The re-certification is a sticker that is installed on the tank. Just had mind re-certified in Lake City Co Cost? Free yup Free took about 15 minutes for them to be inspected.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 12-13-2018, 09:08 PM   #16
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Requalification is good for either 5 or 10 years, depending on the type of test.
Since the "visual" inspection is easiest to do, that is the most common. It is good for 5 years
From the link I provided in post #8:
• DOT 4-series propane cylinders must be requalified following their manufacture date every 5 or 10 years.
If no requalification date is present, 10-years from the date of manufacture.
If requalification was completed by the “Volumetric Expansion” method, as indicated by a valid RIN holder’s requalification mark, 10-years after that date.
If requalification was completed by the “Proof-Pressure” method, as indicated by a valid RIN holder’s requalification mark followed by an “S” 10-years after that date.
If requalification was completed by the “External Visual” method, as indicated by a valid RIN or VIN holder’s requalification mark followed by an “E” 5-years after that date.
Alan
Old 12-14-2018, 08:53 PM   #17
2009 30' Classic
$12.00 here for recertified. In West GA. The gentleman certifying my tank says he is licenced to recertif y in any state he 's DOT national certified . And current law is 10 years. It could change has before.
Old 12-23-2018, 11:37 PM   #18
1973 31' Sovereign
1978 Argosy 30
1985 31' Excella
Sacramento , California
to answer you question.. its the 11 ^ 08... which clearly is past the re cert date... but alu tanks are good for life unless you dent or bend them. They do not rust... but do corrode inside.. so you will need to have them re-certed and then they can refill them...
One other thing that they don't tell you.. is the valve has to be the new OPD type... so if your like mine.. the old valves had the elect sensor and gauge in them.. the new opd's don't... so you have to go the old way by looking at the regulator and see if the tank has changed when empty...
To get the gauges back into them requires a new propane tank with a secondary port on the top deck.... however...
Their are new ways to find out if the propane is at what level in the tank... they put a sounder at the bottom and it then reports to you phone by blue tooth... how much propane each tank has... but...
Its expensive. The rest of us went back to the old look for the red marker in the regulator when empty.. remove and go get filled while its working on the second one...
While your at it though if you need one certified.. might as well take the two of them off the trailer and have 'em both done... then your good for another 7 years... and will have to have it done again...
Also when they change the new valve to OPD... you don't get the full tank anymore.. it comes up about a gallon short on each tank due to the auto shut off inside the tank with the new valve....
You dont have to change the hoses and fittings.. as they will go back into the new OPD valve...
In looking at your pic... the weight of the tank WC seems to be a bit high... is this a regular tank on the frame of the trailer ? or is it on a motorhome...
If its a side mounted (horz mounted ) tank.... you don't have to have it tested or certified.. as they are exempt...
Yep its just a money grab in the rv industry... as most propane tank won't rust from the inside out if propane is kept in them.. but they will rust from the outside in if not taken care of... and that is what they are trying to force out of the field...
Alu tanks should have been exempt except for visual inspection.. but the old tanks won't shut off if the hose burns off... like the new OPD ones will... so it was a resonable safety feature... along with other things that were designed into the OPD valves...
the adventure contenues
G.M> WA6CDE
GM Airstream is offline   Reply With Quote
Old 12-24-2018, 09:37 AM   #19
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
The most common type of recertification in the US is the visual recertification. It is good for five years.
The regulations on filling have always been the same: 80% is the max fill. This applied before OPDs came along, and after. What has changed is the practice by home fillers to fill cylinders right to the top, a very dangerous practice. (Note, too, that professional fillers are not permitted to use the OPD as a means to determine when a cylinder is full.)
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 12-24-2018, 10:08 AM   #20
Usually lost
Cally's Avatar
2007 27' Safari FB SE
Maricopa , Arizona
I had mine recertified and they put a sticker on them. This was not acceptable in Canada and I wasn't able to get them refilled anywhere. I got them stamped when I got back.
Pat, Babs & Riley
Cally is offline   Reply With Quote
Fake Statue of Liberty stamp Arrowstream Off Topic Forum 5 04-17-2011 12:16 AM
Where's the Federal Safety Stamp? fischerbeach Classic Motorhomes 19 01-18-2011 04:45 PM
Locations on Tradewind for Vin number stamp? yochanan Title, VIN & Registration 23 11-18-2005 01:28 PM
