Old 02-16-2007, 08:53 AM   #1
Midlothian , Texas
Unhappy help with my horizontal tanks
Hi,
I need your help. I purchased a 34' limited 1994 airstream trailer last year. What I did not know is that the previous owner had brought the Horizontal propain tanks in for refill and we assume that that particular station only refilled the vertical tanks with the new safety shut off on it because they replaced the Horizontal valves with veritcal ones which of course makes my tanks completely useless. I have called airstream who told me that they do not sell to the public so I called a local dealer that so far could only tell me that each tank would run me $298 plus tax. I would like to know if any one knows where I could purchase replacement valves for my existing tanks? Thanks in advance for your help.
ecgds is offline   Reply With Quote
Old 02-16-2007, 09:02 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Check out these folks. They are pros at with all sorts of tanks, valves and regulators. If you can't find what you are looking for on their web site give them a call. Very helpful bunch of people!
Cavagna Group Spa Advanced Solutions for Gas Control: Omeca Division manufactures high-quality L.P.G. fittings, filling heads and valves for L.P.G. tanks and cylinders
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-16-2007, 09:03 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Originally Posted by ecgds
Hi,
Hi welcome to the forums. I would suggest getting in touch with somebody like National Welders who deal in pressure tanks. Or possibly a fork lift service center. (LP powered forklifts use horizontal tanks) The valves themselves are not terribly expensive compared to the cost of a replacement tank.
Aaron
WBCCI #XXXX AIR #2495
Old 02-16-2007, 09:17 AM   #4
Images: 59
I might be wrong, but I think a horizontal tank needs a custom fitted tube to ensure that only vapor is discharged. Fork lift tanks use a liquid pickup tube and would not work.
Since the orientation and tube length will be critical, I think you might need to take it to a major propane service center to be fitted.
Old 02-16-2007, 10:04 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Depends on the fork lift. We have had both. I was suggesting it as an option in that they should be familiar with the system(s). I have found as a general rule the LP companies around here could care less to do other than sell you one of their new tanks...full of their propane of course
Aaron
Old 02-16-2007, 05:20 PM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
May be these guys could help.
Texas propane outlet directory search results
>>>>>>>>>>>>>>>>>Action
Old 02-16-2007, 06:06 PM   #7
Images: 59
Or you could drive on over to Strickland Propane in Arlen.
Ask for Hank Hill. Hank is a proud recipient of the Blue Flame of Valor award. This is the highest honor that the Texas Propane Gas Association can bestow on a living member in peacetime.
Old 02-16-2007, 06:11 PM   #8
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
His son Bobby is a gas too!
>>>>>>>>>>>>>>>Action
valves for horizontal lp tanks? Oak LP Gas, Piping, Tanks & Regulators 1 10-20-2002 12:26 PM
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 11:36 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 02:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 01:11 PM
