Old 06-12-2015, 09:29 PM   #1
2000 27' Safari
Naples , Florida
HELP PLEASE Gasline Install on 1999 27' Safari
So the main line comes down the passenger side of the trailer under the steel rail and is 1/2" soft copper.
This in turn tees off to the appliances in a smaller size probably 3/8".
The trailer does not look like it is factory as the 3/8" lines are routed through the same size "Retaining Bands" as the 1/2" copper line. So the 3/8" lines are free to move all over the place as the 1/2" bands are used everywhere.
So did the previous owner go cheap and downsize the fitting at the heater, water heater, stove and fridge?
It looks like the 3/8" fits the appliance but under the belly pan it looks like 1/2" copper was used originally.
A few of the 3/8" stuff is crimped at the tee where it fasten set to the 1/2" main line.
If I have to down size for the appliances can this be done with an in-line reducing flared coupling before it goes into the appliance cabinet?
The main reason I'm looking into this issue is I'm adding front stabilizing jacks to the trailer and the main line has to get bent around the lowing bolt of the jack.
As well as wanting to fix the major crimped copper line going to the fridge as we always have issues with the fridge getting powered off of propane and I bet this has everything to do with it.
Advice please as I'm not a Tech but I did stay at a Holiday Inn Express last night.....
map-it is offline   Reply With Quote
Old 06-12-2015, 09:49 PM   #2
1979 23' Safari
Wayland , New York
What you described is normal. 1/2" main line that has individual branches of 3/8" to the appliances.
You'll probably have to add a little length to the main when you rerout it around the stabilizer. Just get a 1/2" to 1/2" flare union to add on the extra length.
The line to the fridge can be fairly long inside the trailer for getting it to the fridge and provide flexibility connecting and reducing vibration transfer. Keep it long when you replace it. Or, if the crimp is exterior, you could try to just cut out the crimp and splice in a short piece. Save running all through belly pan and working to get to fridge.
The clamps holding the tubing up probably came that way from the factory. Crappy I know. If you want to fix them you can unrivet them, wrap a little rubber around them to fill the gap and still provide soft cushion, bike tire inner tube works well, then rivet them back up.
Old 06-12-2015, 09:52 PM   #3
1974 Argosy 20
Kooskia , Idaho
The original main line was most likely the half inch you mention, and the branch lines were all 3/8. I don't think anything was changed by a previous owner. So, I think your system is pretty much original. Airstream used the same bands all over, for the most part. A lot of gas can be carried through even 3/8 lines with the short distances involved. If you are having problems, the first thing to do is to check the pressure from your regulator. Better yet, just replace it, it is 16 years old now, close to it's general life.
If you have a crimp in the refrigerator line, repair or replace it. More likely, after this time it simply needs the burner and burner tube cleaned. Rust and spider webs plus mud daubers get into things and they can't work the way they were designed.
Old 06-12-2015, 10:28 PM   #4
2000 27' Safari
Naples , Florida
Thanks it just looks wired that Airstream would rout a 3/8" line through a 1/2" band.
I'll probably just add length to the main line if that's what you guys recommend.
And of course fix the crimp.
Please help - opinion please - 1967 caravel for $1000 knishiya Airstream Trailer Forums 5 05-11-2012 09:33 PM
Want To Install 3 Stage Charger 1999 Safari Soyboy Electrical - Systems, Generators, Batteries & Solar 3 04-15-2010 05:27 AM
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 09-11-2009 07:40 AM
Used 1999 airstream 28' safari travel trailer used 1999 eBay Watch Airstreams on eBay 0 08-19-2009 10:50 AM
