10-25-2006, 07:17 AM
1962 16' Bambi
Unionville
, Pennsylvania
Heater firing sequence for a '62 Bambi.
I thought yesterday, just for the helluva it, I would try to fire the heater in my '62 Bambi. I can't figure it out. I've gone over it, everything is nice and clean and I don't have any gas leaks. Mine has a thermostat on the wall and an electric ignitor that operates off the 12 volt system. I seem to have power to everything, so I figure there is some safety measure that is overriding me. Thanks in advance for any help.
-Walter.
10-25-2006, 05:24 PM
Corona
-Walter.
Walt.
Several members can offer help, but the make and model must be known.
10-26-2006, 01:38 PM
1971 27' Overlander
Central
Walter,
Did anything happen at all? We just tried our furnace for the first time - it's a Suburban - 1998 model with electronic ignition. The sequence we followed was to turn on the gas at the line next to the furnace. On the thermostat there was an on/off switch we turned on - then raised the temp. on the thermostat until it "clicked". Nothing happened. I left it alone and went back to reading the manual. After about 5 minutes the fan kicked on - it's supposed to do this to purge gases - then it ran at least 10 minutes before it finally ignited. After that it cycled much faster.
10-26-2006, 09:02 PM
1962 16' Bambi
Unionville
, Pennsylvania
Oh cool. Thank you, Gary. I've not yet had a chance to look up the model number on my unit. I think it is as old as my Bambi, but it sounds like yours in principal. Maybe I would have had the same result if I had to spend time reading a manual, but I don't have one. I turned on the gas valve, turned on the "on" switch on the thermostat, raised the temperature (even checked the thermostat for voltage) but I didn't wait anywhere near that long for something to happen. I'll get the model number and check back. If that doesn't yield any answers, I'll give your process a shot.
Thanks so much,
-Walter.
10-27-2006, 07:43 AM
1962 16' Bambi
Unionville
, Pennsylvania
I looked for a data plate, but there are no identifying marks whatsoever. The only information I can find on the unit is the UL tag, but that doesn't tell you anything except their control number.
10-27-2006, 08:03 AM
1962 16' Bambi
Unionville
, Pennsylvania
If it helps, I've now found where both the thermostat on the wall and the exhaust vent plate on the outside say, "Hydro-Flame".
10-27-2006, 05:27 PM
1971 27' Overlander
Central
10-27-2006, 06:06 PM
1971 27' Overlander
Central
Here is a link to a Hydroflame manual:
http://bryantrv.com/docs2/docs/operating/hflameowners.pdf
10-28-2006, 07:24 PM
1962 16' Bambi
Unionville
, Pennsylvania
Thank you for your help, Gary. I'm having trouble with .pdf's a the moment, and I can't get the links you provided to open, if indeed they are links. I get a "Page cannot be displayed" with every one I try to open.
I had thought my unit was original to the Bambi as I didn't know ignitors came into production later and my trailer is so unmolested, it was just an assumption.
I tried what the previous poster stated about turning everything on and waiting, but after waiting 15 minutes nothing had changed.
Whatever labels were there are no more, I've looked on everything. I'll work on getting that .pdf open. Would a picture of the unit help, are you good enough to visually identify it?
-Walter.
10-28-2006, 08:03 PM
1971 27' Overlander
Central
Hi,
The model numbers above will not link to the site I got them from and were not intended to. The web link in the second message, if you will copy and paste it into your browser address, should take you to the instruction manual. Your furnace has been replaced if it has an electronic ignitor on it.
Next suggestion is to get a tube cleaner brush from an RV store and run it through all the feed lines. Dust and spider webs will also keep the unit from firing. A can of compressed air might also help. I'll post another link for you that will take you to an RV dealer that I got this information from.
10-28-2006, 08:15 PM
1971 27' Overlander
Central
Here is the link to the dealer that has this information on their site.
http://www.pplmotorhomes.com/parts/r...?source=google
One thing I noticed is that they refer to a switch on the furnace, beyond the thermostat switch, that controls the power. Do you see anything like that..?
10-28-2006, 09:45 PM
1962 16' Bambi
Unionville
, Pennsylvania
Thanks, the problem with the .pdf is my own and I need to fix that anyway. It is very inconvenient. I'm told it has something to do with my settings not allowing files over a certain size to open. I'll get that taken care of.
I thought I did an alright job of cleaning it, but if it's that finniky I'll go over it again.
I don't see a switch on my furnace, but there is a spring loaded push button where the electrical connections are made inside that I assumed was for striking the ignitor, but it doesn't seem to do anything. I'll look again for an electrical on/off. Also, the gas on/off knob that rotates 180 degrees also pushes in and out, as would a pilot type furnace, but the knob has no pilot indicator.
Thanks for all your help. I'll do some more reading and then play with it some more.
10-29-2006, 04:02 PM
1971 27' Overlander
Central
OK - let's deal with Adobe first. Open it from your list of programs - click Edit and then Preferences - make sure Display Large Images is selected. If it is and you know you have a problem - chose Help - then Online Support - and download the Windows update - presuming you are using Windows.
10-29-2006, 04:19 PM
1971 27' Overlander
Central
Now to deal with the furnace. I owe you an apology. When you said you had an electronic ignitor I presumed it was like ours - it ignites on its own and there is no standing pilot light.
With the valve on a spring set up it sounds like a standard push and ignite to get the pilot light. I'll suggest one more thing.
- make sure the lines are full of gas by lighting the range
- turn the thermostat switch on and slide the temp. down all the way
- open the furnace gas valve and push in then press the ignitor
- this may take a few attempts/minutes
- presume there is a window/panel that let's you see if the pilot is lit
- once the pilot is lit crank the temp. up on the thermostat
Good luck and sorry for the confusion - ahh.. the value of photos.
11-02-2006, 05:03 PM
1962 16' Bambi
Unionville
, Pennsylvania
Sorry for the slow reply, Gary. I don't receive email updates, need to change my settings.
You are the most useful person I've encountered here, thank you for your help. Regarding Adobe, I don't have an option to Display Large Images, or anything like that. My friend, who built my computer and does this as his business, can probably help as he knows what version I have, and such. I'll get that squared away soon.
Secondly, your checklist:
-I have gas to the furnace.
-thermostat on and temperature raised.
-I've turned on and depressed the valve and ignitor. Tell me this: should the ignitor arc regardless whenever the button is pushed? I can't get an arc at all. Maybe I have a bad transformer?
-I have a window, but no luck getting a pilot.
Photos I can post, I know how to do that. Let me try to get something posted for you tomorrow, if that helps. Sounds like I have an ignitor problem.
Thanks again.
11-04-2006, 07:14 AM
1971 27' Overlander
Central
Here see if this helps - yes, I know it's an Adobe file but not able to get it to you any other way.
11-04-2006, 08:38 AM
1962 16' Bambi
Unionville
, Pennsylvania
Hello Gary,
Yes, that does help. Thanks. Opening a saved .pdf from my hard drive is not a problem, just from the internet. I was able to read that. I see in the start-up instructions one detail that I might have missed, I'll try again sometime over the weekend.
