Old 11-02-2006, 06:03 PM   #15
1962 16' Bambi
Unionville , Pennsylvania
Sorry for the slow reply, Gary. I don't receive email updates, need to change my settings.
You are the most useful person I've encountered here, thank you for your help. Regarding Adobe, I don't have an option to Display Large Images, or anything like that. My friend, who built my computer and does this as his business, can probably help as he knows what version I have, and such. I'll get that squared away soon.
Secondly, your checklist:
-I have gas to the furnace.
-thermostat on and temperature raised.
-I've turned on and depressed the valve and ignitor. Tell me this: should the ignitor arc regardless whenever the button is pushed? I can't get an arc at all. Maybe I have a bad transformer?
-I have a window, but no luck getting a pilot.
Photos I can post, I know how to do that. Let me try to get something posted for you tomorrow, if that helps. Sounds like I have an ignitor problem.
Thanks again.
W. Higgins is offline   Reply With Quote
Old 11-04-2006, 08:14 AM   #16
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here see if this helps - yes, I know it's an Adobe file but not able to get it to you any other way.
Old 11-04-2006, 09:38 AM   #17
1962 16' Bambi
Hello Gary,
Yes, that does help. Thanks. Opening a saved .pdf from my hard drive is not a problem, just from the internet. I was able to read that. I see in the start-up instructions one detail that I might have missed, I'll try again sometime over the weekend.
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 03:35 AM
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 51 03-18-2016 02:21 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 11:21 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 08:55 PM
