Join Airstream Forums Today
Old 01-14-2012, 05:24 PM   #1
1972 31' Sovereign
Valdosta , Georgia
Heat from A/C unit
I have started to remodel my 71 32'er and am wondering something about the heating. I live in So GA and plan to camp in fall and winter but not above the mason/dixon. If I add a second A/C unit that has aux heat, will that provide enough heat for the camper in normal conditions? I do not trust a 40yr old gas heater and do not want to invest in a new one if I can get by with the aux from A/C units.
thanks
GaCamper is offline   Reply With Quote
Old 01-14-2012, 05:26 PM   #2
lewster's Avatar
Marco Island, FL , Hood River, OR
A heat pump roof unit will do what you desire, but be advised that they will not work below about 40*F. Newer Airstreams come with Dometic Penguin low profile heat pump units.
Lew Farber -RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS .....MAGNUM INVERTERS.....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
Old 01-14-2012, 05:39 PM   #3
Alumaholic's Avatar
Albuquerque , New Mexico
Lewster has it right. Our heat-pump roof unit (Dometic) works great down to outside temps of about 40 F.
We have a small, utility heater about 8in X 8in X 8in that keeps us toasty below 40.
Ken
Ken
2007Chevy 2500 HD Duramax/Allison
NM Unit WBCCI #8654, Affiliate Four Corners Unit
"Those Airstream photos on the internet that fuel your fantasies will always capture the gleam of aluminum, but rarely all the blemishes, and never the smell."
Alumaholic is offline   Reply With Quote
Old 01-14-2012, 06:43 PM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
Nope. I'm in Florida at the moment, outside temperature is 42 (low predicted at 36 tonight), and our aux heat is NOT keeping up. The furnace however is toasty warm.
1995 Airstream Classic 30' Excella 1000
B190 Owners: The site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
Old 01-15-2012, 06:08 AM   #5
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
... If I add a second A/C unit that has aux heat, will that provide enough heat for the camper in normal conditions? ...
A clarification may help. Will this 2nd unit be a heat pump or a standard A/C with an integrated heat strip?
Our TT came equipped with a heat pump and I've found it adequate into the 30s, albeit noisy (same noise level as running the A/C). I don't know what the output of the integrated heat strip is, maybe some one else will chime in, but I suspect 1 or 2 small portable heaters would do the job. I carry a compact ceramic cube type heater if needed. It served us well in our previous TT. I've read in other threads where some have found the oil filled radiator type heaters to be very satisfactory.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Airstream using new A/C unit? Aviator Furnaces, Heaters, Fireplaces & Air Conditioning 6 11-29-2011 06:08 AM
Under Bench AC with Heat unit truckasaurus Furnaces, Heaters, Fireplaces & Air Conditioning 1 11-24-2011 08:51 PM
A/C Unit from the Mothership... KyMoonshine Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-10-2011 06:56 PM
Best place (price) to buy new A/C unit? adwriter73 Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-12-2011 03:33 PM
Best low profile roof top A/C unit??? hotstuff Furnaces, Heaters, Fireplaces & Air Conditioning 6 03-29-2011 06:08 PM
