Old 09-19-2007, 10:24 AM   #1
tpi
Trabuco Canyon , California
heads up-gas pipe to stove-'05 Safari
You may want to make a quick check of the copper gas line entering your stove.
I lifted the cooktop and saw the copper gas line was rubbing into the steel stove where it entered in the rear. The vibration had already worn a shallow groove into the copper gas pipe. There was a plastic sleeve entirely under the cooktop, I assume it was supposed to protect the gas line where it entered the stove. I pushed it back into position.
If I had not discovered this, the groove eventually would have worn through causing a gas leak.
tpi is offline   Reply With Quote
Old 09-19-2007, 11:21 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Good catch! Sandi has been after me to clean the cook top so now I better get it done and check the line before we head out Friday!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
68 Safari stove top 63Airstream Stoves, Ovens & Microwaves 5 02-14-2007 09:03 PM
Converting gas stove to propane ??? cloud55 Stoves, Ovens & Microwaves 10 11-05-2006 09:11 AM
Dometic M52 (67 Safari) gas flue baffle Joe Hege Refrigerators 4 08-23-2006 09:36 PM
Gas lantern in '67 Safari - need info airdrmr General Interior Topics 10 08-07-2006 12:36 AM
Heads up if you want an Argosy Boondocker All Argosy Trailers 9 03-12-2006 09:56 AM
