Old 09-27-2006, 05:10 PM   #1
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Haunted heater
I seem to have picked up a pesky poltergeist while at the Baker Hotel in Mineral Wells, TX!
For no reason my furnace comes on, and stays on till I pull the hot wire from the electric motor. It's a Hydro-Flame Mod#:8531-III SN#0080356
After a while, I can replace the hot wire and it functions normally and can be controlled from the thermostat.
I suspect the relay mounted on the motor housing.
Any thoughts?
Michael
PS, As we speak it is learning new tricks; now it turns on and off all by it self, Op there it goes again!
I have turned of the internal rocker switch which keeps the propane from firing up, it's hot enough here in TX.
ArtStream is offline   Reply With Quote
Old 09-27-2006, 10:36 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Haunted....
Have you tried garlic? Tie a bunch around the heater knob and click your heels 3 times. Oops, maybe I am confused, that might take you to Kansas!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-28-2006, 04:43 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
if you disconnect the two blue wires at the furnace that run to the thermostat, does it continue to be haunted?
let us know!
john
you call them ferrets, i call them weasels.
Old 09-28-2006, 07:22 AM   #4
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
Thank you from Wichita!
Old 09-28-2006, 07:33 AM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
let us know!
john
Hi John,
I disconnected the blue and yellow wires from the thermostat at the furnace without results.
The only wires remaining are the hot wire leading to and from the relay on the motor housing. Of course, when I remove the hot wire from the relay the poltergeist have no recourse.
Old 09-28-2006, 05:44 PM   #6
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
sounds like it is time for a dinosaur board for the furnace!
put one in mine and it works great!
john
Hot water Heater DClark Water Heaters, Filters & Pumps 15 08-25-2017 02:35 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
'78 Argosy central heater motor home edmatlock Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-22-2002 10:57 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
