Old 03-07-2011, 09:15 PM   #1
Airstreamer
J5MM's Avatar
2012 27' FB International
Bellevue , Washington
Images: 78
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat
It was propane heat that did not run off the batteries. This heater was contained within the wall with a metal grate in front of it. The inside looked like it contained some sort of metal unit and it gave off the most wonderful dry heat ever. They had their ski gear hanging right up above it and it was very toasty warm inside. Also, they had 'zero' condensation issues inside as well.
I wish we could have this same heating set up in our Airstream (2006 25' Safari FB) instead of the forced air (mainly because of the non-battery use but MOSTLY because of that awesome dry heat)
Was wondering if anyone has ever converted to a heat source as this?
{blog}Just 5 More Minutes to Enjoy Non-Stop Outdoor Adventures and Culinary Discoveries in the Northwest with our Airstream ★Blogger for GoRVing.com
J5MM is offline   Reply With Quote
Old 03-07-2011, 09:19 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sounds like a catalytic heater. There are many threads about them here. I have one and it works great.
Richard
Old 03-08-2011, 05:22 AM   #3
Wise Elder
Jammer's Avatar
2010 30' Classic
The heater you describe is no longer made.
Some 1960s-era trailers had Panelray heaters. You probably saw one of those or something similar.
The closest thing available today is the Newport gas heater from Dickinson marine. Several forum members have them and seem pleased with them. Like the Panelray and similar heaters the Newport is vented and doesn't require electricity, but it has an outside air intake so it meets the modern safety requirements.
Old 03-08-2011, 06:31 AM   #4
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Sounds like a catalytic heater to me. They are available at: Olympian Catalytic Heater - Wave 3 - 3000 BTU
A 62' Bambi would not have a panel ray heater in it....no room!
safari62 is offline   Reply With Quote
Old 03-08-2011, 07:25 AM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Sounds (& looks) like what's in our '64 GlobeTrotter...if so, it's a Day-n-Night. I found this picture of a Bambi with one on the Airstream Archives site:
Here's ours - it's a little taller and is built into a cabinet (with access behind it).
You're right it is a very nice "dry heat" it keeps us toastie warm! The only problem is it is a "heater" - not a "furnace" meaning that it is either "on" or "off" there is no thermostat. Most of the time we set it on pilot of just above at night just to keep the chill off - otherwise it's like a sauna. But it heats things up real quick upon arrival or on a cold day...
Similar heaters were used in homes around the same time (at least in CA where we grew up) Mr.InsideOut had a larger version is his house as a kid.
Shari
Old 03-08-2011, 10:04 AM   #6
Airstreamer
J5MM's Avatar
Images: 78
Shari
THAT'S IT!! Oh my -- thank you so very much!! By the way, your upholstery is amazing. I absolutely adore it.
Thank you so much again !!!
Old 03-09-2011, 11:02 PM   #7
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks!
Old 03-10-2011, 08:58 PM   #8
75Excella500's Avatar
1961 16' Bambi
1975 31' Excella 500
Sanford , North Carolina
The heater in my 61 Bambi is a Carlson vented recessed heater made by Pacific Specialty Mfg. Alhambra Ca. Model 6M. 4200 BTU output. It is currently undergoing restoration, I hope. Shari's description is the same for this one also.
Shari, I like the upholstery too.
Ralph
Name:	DSCN1370 (Small).JPG
75Excella500 is offline   Reply With Quote
Old 03-11-2011, 03:14 PM   #9
InsideOut's Avatar
1956 22' Safari
Images: 108
Looks like it's about the same to me...ours is just a little bigger in our GT.
Shari
Old 03-14-2011, 02:52 PM   #10
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Shari
Thanks for posting that with the name- its the same heater in our '64 Globetrotter. I liked that it is like the heaters in some California homes I've known and loved, brrr, not enough to heat a whole house but great for a trailer and easy to fix.
Wherever you go, there you are
Globie64 is offline   Reply With Quote
1962, 1962 bambi
