Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Prev Previous Post   Next Post Next
Old 10-09-2009, 06:20 PM   #1
Profile:  Meadowview , Virginia
Grill/rubber LPG line general question
Guys, I'm new to working with LP gas so bear with me please. I have a small grill that uses the 1 lb tanks that screw directly into the grill regulator. I want to run a 25 ft rubber line from a big (100 Gal) tank to feed my grill without using the small 1 lb tanks. I want to have a quick disconnect on the line coming from my big tank and the other end can be a solid connection to my grill.
How do I do this, does the supply line connect to the grill regulator and if so where in the world do I find a connector that looks like that?
Is a set up like this OK to do, it will only be connected when grilling and everything is outside, thanks for any advice I can get
Resqu2 is offline   Reply With Quote
Around the window-Rubber question mooreres Windows & Screens 3 05-29-2009 05:33 PM
LPG Question from wannibe proliner Winter Living 12 07-07-2008 11:03 AM
Replacing main LPG line from regulator Safari64 LP Gas, Piping, Tanks & Regulators 3 02-18-2008 12:05 AM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 06:06 PM
General Question on AS trailer Alex 1972 Ambassador 7 12-01-2003 10:06 AM
