Old 04-04-2012, 04:54 PM   #29
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Diesel 1..
Your my man! Have used my number stamps several times myself for the same reasons..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 06-15-2012, 07:33 PM   #30
twobikes's Avatar
1997 25' Safari
Montgomery , Alabama
Finally got my tanks re certified --Heritage Propane hear Townsend Tn..Did both tanks NO CHARGE . These folks have be more than kind to us on other occasions. Whenever we camp In GSMNP we fill up here. Finally thought to ask and they were most obliging. So if you are headed to Cades Cove, remember these folks.
PAT & AL MEYER
TAC AL-26 WBCCI 2626
Montgomery, Alabama
follow the Two Bikes and an Airstream blog at http://airgo.blogspot.com
twobikes is offline   Reply With Quote
Old 06-18-2012, 09:06 PM   #31
1968 26' Overlander
Duluth , Minnesota
I took one of the original 30 lb. tanks from my '68 Overlander in to my local propane dealer today. They have 1968 stamped on the neck and are not the best looking tanks you have ever seen. They are replacing the valve with OPD for $30.99 and re-certifying them for free. They said they would do the inspection and not replace the valve if it does not pass.
These tanks have a "bleeder valve" on them. My first question was can they refill with this on there. The answer, "no problem".
New white steel 30 lb. tanks were $60 and they sell aluminum for $120 (special order, 2 weeks).
I bought the Marshall Regulator that they sell for $35. Given what I have read here about failures, I think I will buy another regulator and put it in my tool box. Looking for a simple solution to mount this reg. to my old cast aluminum tank hold-down. Anyone have a good modification?
I went with the replacement copper lines from tank to reg. instead of rubber. Rubber lines make me nervous on an RV. Maybe on the deck on the grill, but not at 65 mph!
ID:	161339   Click image for larger version
Bunkroom is offline   Reply With Quote
Old 06-18-2012, 10:30 PM   #32
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I went with the replacement copper lines from tank to reg. instead of rubber. Rubber lines make me nervous on an RV. Maybe on the deck on the grill, but not at 65 mph![/QUOTE]
Where are you finding the copper lines? I have looked & cannot find them. I have one original copper line on my '67 and one rubber. I would like two new hard lines. Thanks, John
Fortune cookie say....."Prudence keeps life safe, but does not often make it happy."
Diesel1 is offline   Reply With Quote
Old 06-19-2012, 07:00 AM   #33
1968 26' Overlander
Duluth , Minnesota
John:
I bought them at my propane supplier for $5 each! The end fittings alone would be more than that at my local hardware store.
It is a Ferrellgas store in WI.
They use the Marshall auto changeover regulator with the copper lines on dual 100lb. tank setups for cabins and small homes so they keep both on hand.
Old 06-19-2012, 08:11 AM   #34
1968 26' Overlander
Duluth , Minnesota
Try here:
20" Automatic Changeover Regulator Pigtail POLx 1/4 IMF
Old 06-19-2012, 08:41 AM   #35
Diesel1's Avatar
1967 24' Tradewind
Thank you!
Old 06-20-2012, 08:12 PM   #36
1976 Argosy 26
Blandon , Pennsylvania
Remember that with copper pigtails you can get scaling inside them over time. So when you disconnect and reconnect the pigtails, avoid bending them. That is why they use rubber on applications where there is constant movement, especially in tight spots... Also never leave a copper pigtail open to the air for a length of time as air/humidity accelerate the scaling process.
lpgasguy is offline   Reply With Quote
Anyone using these? Regascoe's Clear View LP Tanks? Phrunes LP Gas, Piping, Tanks & Regulators 2 06-15-2013 06:46 AM
Tanks to order and from where? ND10CentCan Waste Systems, Tanks & Totes 14 10-04-2011 08:53 PM
Complacency In Todayís Economy Spells Vanishing Tanks and/or Shore Power Cords! overlander64 Our Community 34 08-18-2011 11:58 AM
