Join Airstream Forums Today
Old 12-19-2011, 06:00 PM   #1
2009 25' FB Flying Cloud
Portsmouth , Rhode Island
Gauging amount of propane in tanks
I have two tanks on my 2009 Flying Cloud 25FB and, because it is necessary to spend quite a bit of time in it this winter, thus running furnace a lot, I am wondering how one tells how much propane is actually left. Are there any "tricks" that anyone has learned, short of actually running out of gas? Thanks in advance!
Jack
JackRenner is offline   Reply With Quote
Old 12-19-2011, 06:08 PM   #2
touched
62overlander's Avatar
1948 22' Liner
Catonsville , Maryland
In the winter you can pour hot water on the tank and the fluid line will show up instantly. As soon as you empty a tank go fill it and you will never be empty.
Frank Yensan The Airstreamer's Club USA-1 "we're dead serious about having fun"
http://annalumanum.blogspot.com/http://frankstrailerworksblog.blogspot.com/
www.frankstrailerworks.com
62overlander is online now   Reply With Quote
Old 12-19-2011, 06:23 PM   #3
"Bess" Full Timers
Mike Leary's Avatar
Suquamish , WA
Images: 13
A dual gauge would be a good idea. However, we took on 25 gallons when we were north on Oct 14th and fueled again with 20 gallons on December 5th. Granted, we have electric where we stay, so the propane use was for our hot water heater, range and furnace, not the fridge. We run the gen-set on propane, but have not used it much other than to exercise it. Hope that helps.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is online now   Reply With Quote
Old 12-19-2011, 06:27 PM   #4
1971 18' Caravel
1974 Argosy 20
1975 Argosy 22 Rear Door
Kooskia , Idaho
Pour a pint of very hot water down the side of the tank. Run your hand down it, you will feel the hot vs. cold line. That is the liquid level in the tank.
idroba is online now   Reply With Quote
Old 12-19-2011, 08:20 PM   #5
moderator
Ottawa , Ontario
There is a small device that will give you visual indication inside the TT of when the switchover happens. The sender part replaces the clear little cap on your regulator, and a thin wire runs into your cabin where a small (~1½" square) black box screws to the wall.
When the changeover happens, an LED (powered by a AAA cell) blinks.
Go pull the empty tank and put it in the truck. Done.
Old 12-19-2011, 09:51 PM   #6
Go pull the empty tank and put it in the trunk. Done.
Just make "SUPER SURE" that the tank is indeed empty, especially in the summer, should you put it in the trunk.
Heat makes the LPG expand, and when it expands enough, the pop off valve will blow off some of the excess pressure.
THAT IS NOT WHAT YOU WANT TO HAPPEN especially in a trunk, since more than likely an explosion will occur.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-19-2011, 10:24 PM   #7
aftermath's Avatar
Spokane , Washington
Why don't you just use the switch over feature on your propane tank setup? I mean, going out and pouring water on the tanks during the cold sounds like a lot of trouble to me. Fill both tanks and open both valves. Keep your eye on the glass indicator and when it turns red take the bottle that the valve is pointing toward in and refill it. Don't forget to turn the switch toward the reserve tank before you remove the empty bottle. You can get a feel for how long a tank will last this way.
No water, no guessing, no hassle.
aftermath is online now   Reply With Quote
Old 12-20-2011, 05:17 AM   #8
2011 30' Flying Cloud
Norfolk , Virginia
I read somewhere that when an LPG tank empties, the propane system will begin drawing from the other even though the switch has not been moved over the the fresh tank. True?
Jack46 is offline   Reply With Quote
Old 12-20-2011, 05:42 AM   #9
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
No real tricks...
The panel monitors have proved fairly accurate and we have always opened both valves to take advantage of the auto switch-over feature of the regulator. When the panel indicates low just check the tank window for the red indicator and fill when needed.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 12-20-2011, 06:16 AM   #10
ventport's Avatar
Milltown , Wisconsin
It draws from the tank that the arrow is pointing to, until that tank runs out of LP. Then it automatically switches over to the full tank provided that you have opened the valves on both tanks. Then when it has switched tanks and one is empty, the window in the regulator turns red to signify that the tank that the arrow is pointing to is empty. Switch the arrow to point to the full tank, and remove the empty tank and get it filled. Replace it and open the valve and you are good to go again.
ventport is offline   Reply With Quote
Old 12-20-2011, 06:21 AM   #11
1981 31' Excella II
Orlando , Florida
My obsolete tanks have a gage on them. If I have them upgraded to make them legal to fill then I will have to remove them and put the newer valves on that won't have gages. Progress is wonderful. There maybe new approved valves that have gages. Andy might be able to chime in here. So Andy are there new valves with gages on them? The hot water trick should work.
Perry
perryg114 is online now   Reply With Quote
Old 12-20-2011, 06:52 AM   #12
This is what I do.
handn is offline   Reply With Quote
Old 12-20-2011, 06:53 AM   #13
1981 31' Excella II
Orlando , Florida
I wondered what that glass indicator was that is now fogged up on mine.
Perry
Old 12-20-2011, 07:19 AM   #14
clancy_boy's Avatar
2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
In situations like the one the OP posted - I would have a 3rd tank full at my camp site. This way WHEN (not IF) I ran out of propane in the middle of the night in a snow storm, I would have fuel to get through the night. The tank I rotate to get fuel would not be that critical in my living needs. BTW - When the weather turns bad the availability of propane becomes a problem - nobody seems to be open.
Michael, Tina & Layla BZ
1966 17' CARAVEL LUCY
2003 22' INTERNATIONAL CCD DESI
Swirl O Matic and BIG aluminum propane tanks Globestream Our Community 3 11-15-2011 11:17 AM
Amazon Propane tanks robwok LP Gas, Piping, Tanks & Regulators 25 02-17-2011 08:02 PM
Rear Propane Tanks? Rob&Julie LP Gas, Piping, Tanks & Regulators 7 02-12-2011 05:38 AM
Propane Tanks and gauges etc. SilverHoot LP Gas, Piping, Tanks & Regulators 13 02-05-2011 09:58 PM
