Old 12-20-2011, 05:25 PM   #29
dznf0g's Avatar
Oswego , Illinois
Isn't this all a moot point since the ACME fitting tanks have a float which shuts off the ability to fill above 80% of the volume of the tank?
-Rich-
Old 12-20-2011, 05:38 PM   #30
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Actually, not. The so-called OPD valves are there to prevent overfill, but they are mechanical devices, subject to possible failure and not regularly inspected. The reason why NFPA first required them was to attempt to prevent overfilling by home fillers. Evidently, the requirement has reduced some of the accidents. And even while requiring the OPD on cylinders, NFPA still requires fillers to use either volume or weight. (Note that many states regularly inspect both filling machinery and scales.)
Lynn
WBCCI 21043
Old 12-20-2011, 05:49 PM   #31
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
And all of this can become a non-issue if we all went to those polymer semi-transparent tanks and could see the level visually. I just don't like the look but they would be covered by the tank cover.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 12-20-2011, 05:52 PM   #32
Baltimore , Maryland
What is a tank cover?
Can they be polished?
Old 12-20-2011, 06:01 PM   #33
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I take my tanks to my Gas Dealer with whom I have an account for OX/Actene and those tanks. They weigh and meter what is put into my tanks.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 12-20-2011, 06:18 PM   #34
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by xo1rider View Post
I'm in the "open both tanks and wait for the change over camp" I just have one question.
Has anyone parked the trailer close enough to a propane filling station to fill the empty tank without taking it out? Or is that o.k. and safe to do that way?
You probably could, but I'm not sure why you'd want to.
As a former B190 motorhome owner, I can say that one of the things I hated the most about the motorhome was having to drive the camper to get the propane tank filled every time. Believe it or not, I now actually enjoy driving the truck (and JUST the truck) to the gas station to get a propane tank filled. It's a minor thing, I know, but it always really bugged me with the motorhome. I grew up with travel trailers, which is probably why I feel this way.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 12-21-2011, 12:30 PM   #35
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
What is a Tank Cover
AS the name implies, a tank cover is a highly polished, clear-coated cover that covers both tanks. Tank valves are accessed via a piano-hinged, painted cover, as shown in the picture.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 12-21-2011, 12:56 PM   #36
Wise Elder
Jammer's Avatar
2010 30' Classic
Lynn
The OPD is supposed to be a safety device, not an operating control. It's still possible to overfill a tank with one, especially when gravity filling them.
I had always understood the reason for the OPD valves to be to address a very specific accident scenario:
1) Homeowner with BBQ grill takes 20# tank to store to have it filled
2) Insufficiently trained, apathetic, minimum wage individual overfills tank
3) Homeowner puts tank in trunk of sedan and drives home in the hot sun
4) Heat of trunk leads propane to expand and vent through relief valve
5) Sedan explodes from accumulation of propane in the trunk
RVs were never really part of the problem, because RV propane tanks are usually mounted on the tongue in a bottomless enclosure, or at worst in a well-ventilated locker. It's hard to imagine enough gas accumulating to reach the lower explosive limit unless the RV is parked indoors or maybe in a depression with no wind, and the accident history isn't there.
Old 12-21-2011, 01:47 PM   #37
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
Ummmm, Kevin - I think Frank was taking a shot at me but I thank you for the picture and description in case he has taken off his aluminum helmet and is being bombarded by gamma rays.
Old 12-21-2011, 03:37 PM   #38
1981 31' Excella II
New Market , Alabama
If the tank is upright when you fill it then you can't overfill it with an OPD valve. It has a float on it that shuts the valve off. Turn it upside down and it does not work. I really don't see the need for a OPD valve in this case. I would have to downgrade my tanks to put that stupid valve on. Gas companies know how to fill them but the law says not to fill a non OPD tank. It is government messing in our business.
Perry
Old 12-21-2011, 04:11 PM   #39
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
In fact, it's 50 different laws as this is a state matter, not a federal one. Actually, it's fewer than 50 since some states don't have any laws in this regard. And at least one state that I know of did not adopt the NFPA recommendation that all DOT cylinders would have to have OPDs.
Lynn
Perry
WBCCI 21043
Old 12-21-2011, 05:46 PM   #40
Vintage trailers do not have tank covers. Many of us sport polished aluminum tanks that our wives can apply lip stick by. New trailers hide their tanks behind modern Airstream aluminum. My post was a pun directed at Clancy Boy. He knows I am a vintage snob and am very proud of it. I know exactly what a tank cover is and that it indeed cannot be polished.
Old 12-21-2011, 07:34 PM   #41
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
As I said before - there is some gamma ray exposure and some living to far north damage going on there. "wives" plural, how do you afford aluminum tanks?
Old 12-22-2011, 03:57 AM   #42
Only one wife at this point. If I could find another as good as my current one, I gladly consider a second or third. I did however say "Many is us..." meaning I was speaking for more than just me as a vintage owner.
Swirl O Matic and BIG aluminum propane tanks Globestream Our Community 3 11-15-2011 11:17 AM
Amazon Propane tanks robwok LP Gas, Piping, Tanks & Regulators 25 02-17-2011 08:02 PM
Rear Propane Tanks? Rob&Julie LP Gas, Piping, Tanks & Regulators 7 02-12-2011 05:38 AM
Propane Tanks and gauges etc. SilverHoot LP Gas, Piping, Tanks & Regulators 13 02-05-2011 09:58 PM
