Old 05-17-2015, 01:07 PM   #1
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Gauges on 30# aluminum tanks
On our '96 34' Excella, we have 30# tanks. I just completed a "remodel", (well almost completed), we've only had the trailer out once for a week on the shakedown trip. I had both tanks recertified and refilled, both guages registered "full", and the monitor on the range hood indicated "full".
This trailer has a gas only hot water heater, and on the first weeks trip, using only the water heater and the kitchen stove on gas, the tanks indicated "full", so I assumed they were both full.
The gas system has no leaks, it was manometer checked before the weeks trip.
This morning, I checked the monitor panel on the range hood, and both tanks registered "full". I wanted to remove some rust on the A frame, so removed the tanks, one of them was empty, but the guage on the tank registed "full". The other tank the gauge registered 1/4 full, and it was full.
Obviously, before I get into the wiring of the monitor panel, I need to replace these tank guages. Have any of you had experience with this, or should I just take them to the local LP thief, and let them deal with it?
Comments, (constructive ones) are appreciated...
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 05-17-2015, 09:50 PM   #2
1998 30' Excella 1000
Livingston , Texas
I'm assuming when you say that the tank was empty but the gauge read full, you are talking about the gauge on the tank itself.
The "float" for the newer required OPD valves can hang-up/interfere with the "float" for the gauge, depending on how the former was installed. By shaking the tank up and down and side to side, in both vertical and horizontal positions I usually get the gauge float to free up. Sometimes I have to use up some of the propane and try a second time. Once I had to add propane before I could get it to free up.
Siegmann is offline   Reply With Quote
Old 05-17-2015, 09:54 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Not good to overfill. But the cylinder maker sells the replacements.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-18-2015, 06:17 AM   #4
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Yes, that's correct, the guage on the tank itself shows "full", and registers "full" on the monitor panel on the range hood, however that tank is empty.
On the second tank, the tank guage registers 3/4, but shows "full" on the monitor panel.
When the tanks were recertified last winter, new OPD valves were installed at the same time.
Larry C
Old 05-18-2015, 08:42 AM   #5
Livingston , Texas
That's when my issue started; after new OPD valves were installed. Try my shake technique.
Old 05-18-2015, 09:10 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Thanks for sharing the "shake" technique! You might add to the procedure by shaking first, and if that doesn't work, "bump" it (vertically) on the driveway.
3 very firm "bumps" freed the one that was empty, but the guage registered full. It went to empty. Now, I'm going to have it filled and see where it is.
The monitor panel still registers "full" on that tank, so apparently there is either a broken wire, or a bad ground somewhere...
Maybe people could call us "The Shake and Bump Folks"
Larry
Old 05-18-2015, 09:28 AM   #7
dznf0g's Avatar
Oswego , Illinois
When I got my AS used....one of the floats was hanging. I could shake it loose sometimes, and sometimes not. I took it to a full service LP distributor. He emptied the tank (to the atmosphere, much to my surprise) and removed the gauge and rotated it a bit. Problem solved. It was hanging on the OPD mechanism.
In my experience, the tank gauge and the monitor will never match exactly, but mine show empty by the monitor with maybe a couple pounds left in the tank, which is good enough for me. Make sure the electrical connections are clean and tight. Any undue resistance in the circuit will through off the monitor. Mine are accurate to 1/8 - 1/4 tank.
-Rich-
Old 05-18-2015, 04:03 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
Another possibility is that the gauge face itself is sticking due to age and corrosion.
The float gauges have a magnetic connection to the needle on the gauge face making it easy to replace the gauge face assembly even while the tank has propane in it. VTS has the replacement gauges and can help you be sure you get the one with the remote electronic sensor you need.
Old 05-18-2015, 08:45 PM   #9
2016 30' Classic
Erie , Colorado
The gauge is a very simple device and prone to failure. Basically there is float at the end of a long tube. As the float drops it turns a shaft in the tube which in turn moves a magnet up under the gauge. The gauge is not directly connected to the shaft. To many chances of leaks. The typical fault is the float becomes stuck.
Find a propane shop or a hot air balloon repair station. Fix is to drain the tank, remove the gauge and lift out the float shaft. Sometimes they can be cleaned other times replaced.
Used Worthington tanks for years flying hot air balloons. The gauges were always treated with skepticism. Better to know your systems and consumption rates.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 05-19-2015, 07:44 AM   #10
1996 25' Excella
Tillsonburg , Ontario
The Bump technique works!
I had a cylinder in Texas that wouldn't take propane. The filling station bumped the cylinder on the ground and it shook loose the OPD.
JCW
JCWDCW is offline   Reply With Quote
Old 05-19-2015, 08:03 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Larry C
I have a 2008 Classic 25fb with aluminum tanks. When do the tanks need to be recertified? I thought aluminum tanks were exempt from that sort of thing.
Kelvin
Old 05-19-2015, 08:05 AM   #12
dznf0g's Avatar
Oswego , Illinois
Kelvin
IIRC, it is at the 12 year mark.
-Rich-
Old 05-19-2015, 09:12 AM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
The newer ones will already have OPD valves and just require a visual inspection.
Gauges on Propane Tanks RichHog LP Gas, Piping, Tanks & Regulators 26 05-10-2014 07:30 PM
Propane Tanks and gauges etc. SilverHoot LP Gas, Piping, Tanks & Regulators 13 02-05-2011 09:58 PM
Gauges.. How to... FrankR Electrical - Systems, Generators, Batteries & Solar 1 01-16-2003 05:51 PM
Engine Monitoring, gauges etc. thenewkid64 Mechanics Corner - Engines, Transmission & More... 1 07-25-2002 02:25 PM
OPD valve w/sight gauges 83Excella LP Gas, Piping, Tanks & Regulators 1 04-16-2002 07:21 AM
