My gas water heater, an Atwood G10-2, won't stay lit long enough to heat up the water. The pilot will light just fine, and heat up the thermocouple long enough to start the main burner if I quickly switch from "pilot" to "on". Sometimes the pilot will blow out for a second, and then relight itself, when the initial rush of air comes through when the main burner starts. Everything appears fine, then after approx. 30 seconds, the flame will shut down as if the water has reached it's temperature setpoint (which it hasn't) with an audible "click". I then can restart the whole process and get it to run for another 30 seconds. Here's what I've done so far in the last couple of days:
1) Replaced the gas valve for the water tank.
2) Replaced the pilot light/themocouple assembly.
3) Blown out the flame tube in the water heater.
4) Diconnected the gas supply at the water heater gas valve and checked for any obstructions. Opened valve at propane tank to let some gas flow through line.
Nothing helped, so I suspected that my gas pressure might be too low. So I lit all 4 burners on the stove, lit the oven burner and started the furnace all at the same time. The burners on the stove and the oven had good flames, and the furnace was putting out heat. Now I am back at square one
. I will try to verify that my lpg regulator has 11" WC. I will also try tightening up my thermocouple fitting (I installed it hand tight plus 1/4 turn per instructions). Has anyone had similar experiences? Please Help!
