Join Airstream Forums Today
Old 12-17-2010, 08:07 PM   #1
DanielB's Avatar
1974 31' Excella 500
Huger , South Carolina
Gas piping replacement
I have to replace the entire LP piping system in a 74 31'.
I have the diagram so I'm good there.. What I'm exploring now is what materials to use. From what I've gathered so far, the best bet is to go with the "black" pipe for the main line and use copper for the offshoot lines that go to the appliances.
Some pipe cutting and threading doesn't seem so bad.. is this really the best/safest way to go with this?
DanielB is offline   Reply With Quote
Old 12-17-2010, 08:28 PM   #2
You can use copper tubing, for all of the LPG lines, as Airstream has done.
However, no splices or "T's" are allowed in the interior.
All the tubing, must be exposed, except when it goes thru the underbelly and thru the floor, into the trailer.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-17-2010, 08:36 PM   #3
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Daniel,
I know others will agree when I say that it is the only way to go. When you are strapping the copper line on to the underbelly, make sure that you use rubber insulators, so the metal doesn't rub through the line.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
TAC # US-7
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 12-17-2010, 08:39 PM   #4
DanielB's Avatar
So copper for everything? Should be easier than cutting and threading the black pipe.
Did they ship my floor channel?
Old 12-17-2010, 08:45 PM   #5
It should ship Monday from Ohio, in 4 foot pieces.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-17-2010, 09:05 PM   #6
DanielB's Avatar
Awesome. Thanks.
Old 12-17-2010, 09:14 PM   #7
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Send a message via AIM to Dave Park Send a message via MSN to Dave Park Send a message via Yahoo to Dave Park Send a message via Skype™ to Dave Park
That's code. Code is really particular about the "no tees or joins inside the trailer" rule. It's also safer.
TX-16
Dave Park is offline   Reply With Quote
Old 12-17-2010, 09:24 PM   #8
wasagachris's Avatar
1973 31' Excella 500
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
Send a message via Skype™ to wasagachris
No shut off valves inside either. Also code.
wasagachris is offline   Reply With Quote
Old 12-18-2010, 01:01 AM   #9
Maniacal Engineer
barts's Avatar
Menlo Park , California
The stove and fridge both have such from the factory on our '71, though.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 12-18-2010, 10:12 AM   #10
moderator
Ottawa , Ontario
- Bart
Ditto. As do all AS TTs I have seen.
Looking to sell your Airstream or buy a different one?
Or maybe you need a part or just want to sell one?
Be sure to look in at http://www.airstreamclassifieds.com
Old 12-18-2010, 11:23 AM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Mine as shut offs for the fridge, stove and furnace. We have updated the appliances but the shut offs were original from the factory.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 12-18-2010, 12:59 PM   #12
1961 30' Sovereign
1947 22' Liner
Durham , Ontario
shut offs were allowed inside in the 70's but not now. If you are replacing the propane lines leave them outside the trailer. Personally I don't intend to reinstall them in my trailer when I do the propane lines. More connections are more points that it can leak.
Old 12-18-2010, 01:35 PM   #13
lewster's Avatar
Marco Island, FL , Hood River, OR
Be certain when buying the copper tubing that you get 'Type K' or better tubing that is specifically rated for LPG use. Make sure that you don't get the refrigeration grade copper.
Lew Farber -RVIA Nationally Certified Master Tech.... MASTER TECH RV SYSTEMS, INC.
AM SOLAR SALES & INSTALLATIONS .....MAGNUM INVERTERS.....LIFELINE BATTERIES
NO MORE AIRSTREAM.... NO MORE MEMBERSHIPS....BUT I'M STILL AROUND!
Old 12-18-2010, 02:15 PM   #14
DanielB's Avatar
Nice tip. Thanks.
I don't think that I can depend on the people who work at these stores to know anything about anything.. except when break time is..
CPVC Piping bwoodtx Plumbing - Systems & Fixtures 2 04-14-2010 07:17 AM
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
Gas Fumes/Carburetor replacement thenewkid64 Mechanics Corner - Engines, Transmission & More... 35 06-18-2004 06:27 AM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
Hot water piping Pahaska 2003 International 8 01-29-2003 07:19 AM
