Join Airstream Forums Today
Old 01-15-2011, 07:53 PM   #29
airdoxy's Avatar
1958 22' Caravanner
gregory , Michigan
Thanks all.. this is a very helpful thread. J.Page
airdoxy is offline   Reply With Quote
Old 01-15-2011, 09:22 PM   #30
TouringDan's Avatar
1966 24' Tradewind
1984 31' Excella
Lynchburg , Virginia
I have a flairing tool and I think it is for a single flair, but I don't know. What does a double flair look like and where do I buy a double flair tool?
Thanks, Dan
Old 01-16-2011, 10:29 AM   #31
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The next time you go to an auto parts store; ask them to show you a piece of steel brake line. It will be double flared. If you know what the single flare; which makes the end of the tubing flared out kinda like the horn of trumpet. They will probably have a double flare tool set. I would not expect it to be cheap.
Old 10-04-2011, 06:19 AM   #32
1969 27' Overlander
Albuquerque , New Mexico
Double flaring tool
I bought a double flaring tool at Harbor Freight for under $20.00
I don't like buying foreign made, but Craftsman wanted over $100. That's just ridiculous!
edglenn is offline   Reply With Quote
Old 10-06-2011, 01:35 PM   #33
1981 31' Excella II
Orlando , Florida
I never heard of needing a double flare for gas lines. We use single 37 degree flares for 1000's of psi here at NASA and we are dealing with stuff alot worse than propane. Double flares are used on steel brake lines and that is probably because of the extreme pressures you are dealing with.
Perry
perryg114 is online now   Reply With Quote
Old 10-13-2011, 06:18 AM   #34
1969 27' Overlander
Double flared fittings, Rectorseal, and petcocks.
I know that the newer code requires double-flared connections, but all the old trailers have single flare, which is fine for the low pressure propane (10-30 inches water column is only a couple p.s.i.). That's what I'm using, and it isn't leaking.
I use the yellow #5 Rectorseal pipe sealant on all my connections. A lot of people insist that you don't need sealant beacuse it's a flared fitting, blah, blah, blah. But if you disconnect and re-connect single flared fittings too many times, it WILL leak. Maybe that's why the newer code has double-flared fittings. Or the engineers got bored.
So use the Rectorseal, and you won't have any problems.
I am also adding individual petcocks (shutoffs) underneath, for each appliance. It's pretty easy. Loosen a couple of the clamps holding the propane line that feeds the appliance, disconnect the 3/8" line at the 1/2" distribution T (main line), and pull the propane line back a few inches. Install a 3/8" x 3/8" swivel connector, add the petcock, and connect the old propane line to the petcock. Make sure all the connections are tight, and re-attach the clamps.
You don't even have to make new flared connections!! Test for leaks, and you're good to go.
Just my 2 cents worth.
Old 10-13-2011, 04:50 PM   #35
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Perry
Aviation uses 37 degree flared fitting but Commercial uses 45 degree. All aircraft oxygen systems, low and high pressure, require double flare per the FAA. A double flare will always seal better when using the softer alloys then the single flare. I too have used single flare on the larger stainless steel flared fitting. For high pressure I prefer the MS flareless fittings. In my opinion the Swagloc fitting are the best all around but they are not approved for aviation use, but I understand that the US Navy uses them on the Subs. I will be using a lot of these on my Airstream and most likely on the propane also, however it will be better then the requirements set up by the RV industry, but they will not be flared.
Old 10-13-2011, 05:08 PM   #36
1981 31' Excella II
Orlando , Florida
Well plumb the whole thing in stainless steel. I like swaglock compression fittings and I would have no problem using them. I used them on my house propane system eventhough it is not code.
Perry
Old 10-13-2011, 05:11 PM   #37
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
Central , Texas
Send a message via Yahoo to Top
Hose option
Earthbound RV is using flexible hose and what looks like an aluminum block manifold on their RVs. Looks like a different approach. I'd be interested to see all the specs in detail. I also wonder how easy it would be to fabricate new hoses if needed. See page 21 of the attached Earthbound Factory tour PDF.
Lance McEwan
Top's Texas Vintage Campers
Central Texas
Top is offline   Reply With Quote
Old 10-28-2011, 08:22 AM   #38
1968 22' Safari
San Antonio , Texas
Ok, no fittings beyond tee at main line, got it. So what about installing a cooktop see video does this guy have it wrong or not.
I'm confused!!!!!!!
Map_man is online now   Reply With Quote
Old 10-28-2011, 08:58 AM   #39
1969 27' Overlander
Undercarriage propane lines.
This is how I ended up running my propane lines:
Main trunk line is 5/8" (factory), most of which was re-usable. I added a pvc pipe at the trailer tongue for protection, and also used and additional braided hose that I split, and wrapped around the new propane sections. Rocks can really damage things at 50-60 m.p.h.!
Here's the main supply line:
Here's the 1/2" lines, routed underneath:
I added gascocks at ALL penetrations. I had to use a swivel flared fitting to connect to the original "T", and then add the gascock and new propane lines. New lines went into the trailer from there. Note that I used braided hose as an additional prtotective layer on the copper 1/2" lines:
I also used yellow #5 Rectorseal on all the fittings, and checked for leaks. Works fine!
CPVC Piping bwoodtx Plumbing - Systems & Fixtures 2 04-14-2010 07:17 AM
PVC piping Devoman Fresh Water Systems 8 09-30-2005 07:46 PM
Gas Fumes/Carburetor replacement thenewkid64 Mechanics Corner - Engines, Transmission & More... 35 06-18-2004 06:27 AM
Belt replacement on 454 Gas Classic AccessMaster Airstream Motorhome Forums 12 05-03-2003 12:31 AM
Hot water piping Pahaska 2003 International 8 01-29-2003 07:19 AM
