Old 11-14-2008, 08:39 PM   #1
oldtrucksrul's Avatar
2009 27' FB Classic
Southlake , Texas
Gas or No Gas, that's the question...
Ok, here is my problem. I am trying to decide to go with or without propane. My wife really wants a gas range. But, I was considering going all electric. What should be my considerations going forward? Cost seems to be one of the best reasons to go all electric, I'm over running my buget I'm also concerned about refrigeration cooling while on the road. Another thing I was considering was running all of the plumbing for propane so when an appliance breaks and I needed to replace it, I would then have the ability to go with gas at that point with less trouble. This also could be a selling point for the next owner.
Let me have it. I want a good discusion. Oh and I'm not planning much boondocking but, it would be nice to have the ability to at some point the inlaws driveway.
oldtrucksrul is offline   Reply With Quote
Old 11-14-2008, 09:23 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The big advantage of propane is that when you don't have shore power, you can still function...refrigerator (while parked and on the road), furnace, stove top, over, etc. You'd also need to install an electric water heater. Going all electric would be OK if you never plan to go without electricity... but then there's that old "never say never" thing...and it could detract from resale possibilities if you limited it to electricity. Propane is still fairly economical and readily available...and having a set-up where you canuse a combo is great.
TB & Greg and Abbey Schnauzer
#3954
Old 11-14-2008, 09:31 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I gave some consideration to this as my coaches were refurbished, but realized that all-electric would pose several problems for the way that I travel.
  • Stopping at scenic roadside rest areas for lunch is one of my favorite passtimes. It is so nice to be able to go into the coach and prepare a bowl of soup and a sandwich -- or re-heat some of the left-overs from the previous evening.
  • For rallys with limited electric, it is imperative to be able to run the refrigerator on LP as electric use for refrigeration is discouraged. I am, however, a proponent of the 3-Way RV refrigerator as I like to travel with mine in 12-volt mode (have been doing this since 1980).
  • An ice storm last winter reminded me of another reason -- the Overlander was warm and comfortable the three days when we were without electricity (it has 3 Gel-Cell batteries and 3 Solar Panels) -- had about 10 pounds of LP left when the electricity came back on (the twin 40 lb tanks were full prior to the storm).
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
Old 11-14-2008, 09:33 PM   #4
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I'd definately keep the gas, simply to have the freedom when you're out to do what you want without having to find a power source. Sent you a PM with a lead on appliances source we used that saved us tons of money.
goransons is offline   Reply With Quote
Old 11-14-2008, 09:58 PM   #5
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
I side with your wife in terms of a gas stove top for cooking -- much better control of heat input. For baking, most cooks prefer electric, but one must make compromises in a travel trailer.
Also, if this is your '48 you are talking about, it would have had at least one, maybe two, propane lamps for lights. Batteries these days have greater ampacity for a given size than they used to, but it still would be prudent to provide yourself with diverse alternatives for light.
If you were to go all-electric you'd probably need a diesel generator in the 7KW size if you wish to deploy heat or A/C and cook at the same time, plus operate a refrigerator simultaneously. That means losing some significant storage somewhere between the hitch and axle, coupled with the necessity of counter-balancing with your waste water and fresh water tanks.
Finally, I'm a 'belt and suspenders' kind of guy, so it just seems right to have both LP and electric (and kerosene lamps, charcoal grill, etc).
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 11-15-2008, 12:07 AM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Need more amps.
Hi, you might have to rewire to whole trailer with a 50 Amp circuit, because 30 amps won't cover much more than maybe an air conditioner and water heater. [micro-wave, toaster, coffee maker, hair dryer, refrigerator, TV, hot plate, battery chargers, and more.] What it would cost to convert everything to electric, would buy a lot of propane. If you are going to have an electric stove top and oven, you might need a 240 volt system.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-15-2008, 06:25 AM   #7
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
I guess I'm the lone ranger here on the other side.
I've been all electric but then I don't have but a fridge and microwave.
I just emptied my storage locker and have the old frame tank that I was going to put on my former rolling showroom.
I do miss the propane heat of the old setup.
I've done a lot of boondocking (at Wal-mart) over the years and have had few nights that I actually wanted gas for heat.
Though I'm all electric the real missing item from my coach is the propane furnace.
I've got a Honda 6010 to supply all the juice I need while untethered.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 11-15-2008, 10:10 AM   #8
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Gas. Much better for boondocking. On a cool morning when I heat water on the stove for coffee it warms the trailer nicely and encourages, Lynn, to finally crawl from under the covers.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-15-2008, 10:31 AM   #9
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Gas........
Everything on our Caravel runs on gas or 12v except the A/C, microwave and coffee maker. When boondocking we use a small Honda generator for the microwave and coffee maker or do without the microwave and use a percolator.
I would give up the 110v before I would give up the gas..
True story.......
Old 11-15-2008, 11:59 AM   #10
2009 27' FB Classic
Southlake , Texas
This solidifies what I thought. Thanks for the comments. I'll be going propane. I want a trailer I'll use.
Old 11-15-2008, 01:26 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
You'll be doing it right, you won't have to do it over.
Old 11-15-2008, 11:18 PM   #12
1972 31' Sovereign
Dallas , Texas
Mine is restored to all electric except for cooking and retained the 30 amp service. I did it by putting in a new a/c unit on the roof that also serves as a heater as a heat pump, no strip heating. I put in a new energy effecient 10 cu.ft. refrigerator freezor that is rated for 1.2 amps max, and also have a small microwave. I have pulled the old furnace out to put in a drop in propane oven and cook top combination. The water heater has 110v plug on it so I run a separate extension cord to the 110v plug on the rv hookup.
So long as I am at an rv park or have at least a 5kw generator with a 30 amp output along with a 20 amp outlet I can keep everything running including two computers and the lights. I just got back from 6 weeks in it down on the Houston coast while doing adjusting in Houston.
If I were to put in an electric oven and cook top, I know I could not do it on a 30 amp and have the a/c or heater running while cooking, but I don't like electric cooking.
The trick to staying at 30 amps is to purchase energy effecient low amp devices. Most computers stay below 1/2 amp but monitors can pull more so an LCD monitor for lower watts can be used. I was running a full size computer with a large crt monitor along with a lap top computer and a printer/scanner and did not have any trouble. I do have a new breaker panel with two 20 amp breakers. One runs only the a/c and the other runs all of the 110v outlets and the 12V converter.
I use a hardwired 600 watt inverter (5 amp) in my truck to operate 110v devices such as my computer. I have not researched the capacity of my converter in the trailer yet, but if it will support it, I will plug in a 300 want inverter into the 12v accessory plug next to the refrigerator and run the refrig on it while towing. If the aux. 12 volt from the truck is not sufficient to support this, I will rig a large inverter in the back of my truck and run an extension cable from the truck to the refrigerator somehow to keep it going when needed.
Hope this helps you a liitle bit. You can purchase the refrigerator from Home Depot for $299 and has a separate freezer on top.
rhansen is offline   Reply With Quote
Old 11-16-2008, 06:13 AM   #13
2009 27' FB Classic
Southlake , Texas
Very interesting. Thanks
Old 11-16-2008, 06:46 AM   #14
1973 31' Excella 500
Morristown , Tennessee
The question should really be trvel trailer or stationary structure. There is no capability when traveling inless you plan to start and stop a generator. Operating equipment on the TV alternator strains it's capability and shortens life expectance. The original propane refrigerator can be operated if stationary or mobile or in places where there is no hook-ups.
The discussion boils down to mobility. Best of luck with either scenario and keep everyone posted with pictures if possible.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Locking Gas Cap for 2003 AS Gas Motorhome spat61 Land Yacht/Legacy Motorhomes 11 10-27-2008 11:37 AM
Question about Gas Mileage LotusBloom Sprinter and B-van Forum 8 07-05-2008 04:04 PM
LP Gas Question, Run 24/7? erikjware Furnaces, Heaters, Fireplaces & Air Conditioning 8 06-05-2008 06:28 PM
Winterizing 2003 LY (Gas) Question spat61 Land Yacht/Legacy Motorhomes 5 11-07-2007 12:56 PM
LP gas line question 63air LP Gas, Piping, Tanks & Regulators 5 01-21-2007 09:41 PM
