Old 12-10-2006, 09:24 AM   #1
jemison , Alabama
gas logs
Would it be reasonable to heat my airstream with the small 12" propane logs? I have no furnace so I'm looking into my options. I will be moving to the cold in a week. Thanks.
rama777 is offline   Reply With Quote
Old 12-10-2006, 09:36 AM   #2
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
room for fireplace?
Do you have a fireplace now? I like your idea except--I have no fireplace and my wife objects to my throwing out the dining table and I would like a electric fireplace where the table is now.
I guess we hold our plates in our laps
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 12-10-2006, 09:37 AM   #3
Craftsman
Guest
Posts: n/a
Take a look at these. There's even one installed in an Airstream. Traditional Cast Iron Marine Stoves by Navigator Stove Works,Inc.
Old 12-10-2006, 09:47 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Are you talking about a vented setup with propane logs? (Don't want carbon monoxide buildup!) How cold will you be getting?
With your vintage you may have copper pipes -- they are fairly easily destroyed on freezing. The furnace you no longer have used to duct heat in all below cabinet spaces that contain water pipes. You'd have to monitor temps in the pipe areas if you do use a space heater. A variety of heaters have been discussed -- maybe search on space heater?
5 meter Langford Nahanni
Old 12-10-2006, 09:53 AM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
No, If you are going to heat your unit make sure that the heating appliance is rated for use in a trailer. Carbon Monoxide is the big problem. Trailers being sealed so tight require that you use outside air for combustion and vent the combustion products to the outside also. If the heating appliance does not do this it is not a good idea to use it. This is one of the reasons you see the warning labels on your gas stove "Not to be used for heating"
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-10-2006, 12:49 PM   #6
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
I'm gonna weigh in with JH and also say no on the 12" gas logs.
Standalone gas log sets are intended for use in a fireplace that has a good draft to remove carbon monoxide, as well as the large volume of fresh air of a house, not to mention some constant source of fresh air.
Wood/coal stoves, including marine versions, are generally not rated for use with just any old set of propane logs. Stove manufacturers have gas-burning stove setups specifically for that purpose.
I wouldn't recommend even the unvented gas fireplaces and stoves rated for mobile home use because of the much smaller volume of a travel trailer.
There are vented marine gas stoves suitable for use in a travel trailer. Some examples are posted in the forums here.
We keep our Airstream winterized year round, and bring water and a porta-potty aboard, and don't use the sink drains when we want to use it. Even with a vented marine gas stove, but without forced air heating ducted below the floor to keep your tanks and plumbing freezing, I strongly suggest you do the same.
Depending on where you are and how cold it gets, even WITH forced air heating ducted below the floor, you may need to skirt the trailer to eliminate the effect of wind chill, which removes heat faster from the underbelly than stationary cold air. Without this, even the ducted hot air may not be able to keep up with the heat loss.
Even with a vented stove or RV furnace that vents the products of combustion (one of which is water) outdoors, humidity from your breath, bathing, cooking and washing dishes can be a serious problem in the small volume of an RV. The condensation that results from it can cause damage inside the unit. Besides having a dehumidifier, the main way to fight that is by venting the hot, humid air at one end of the RV and introducing cold, dry fresh air at the other. That's also a good thing if you like to breath, but it adds to your heating load.
Just some thoughts... hope they help.
Maurice
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Squirrel Eating Gas Lines! lbrodsky LP Gas, Piping, Tanks & Regulators 8 07-06-2002 10:03 AM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
