Old 11-04-2006, 02:24 PM   #1
kamo's Avatar
burbank , California
gas lines inside
I'm installing new gas lines on my '62 Bambi. I'm adding a large holding tank in the back, so I cannot run the gas line all the way back to the fridge under the RV.
My plan is to supply the stove and fridge from a tee off the water heater. This means however more gas lines inside.
Is there any reason I should not do this?
Kamo
kamo is offline   Reply With Quote
Old 11-04-2006, 02:51 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
there is a very good reason to not do this Boooooom!
If you run the lines inside and have aleak it will pool in the belly pan. Eventually the gas will find its way to some source of ignition. Furnance or Water Heater, possibly the fridge.
Bad idea.
Michelle TAC MT-0
Sarah, Snowball
Old 11-04-2006, 02:55 PM   #3
Images: 59
I faced the same problem. After much consideration, I ran the gas line all the way to the other side, then along the side of the wheel well, then back across to the water heater. It was tough to avoid the tank, and it took more tubing.
But I can sleep peacefully.
Old 11-04-2006, 03:20 PM   #4
Kamo
Let the "big bang" theory stay with the astronomers.
ANY AND ALL copper tubing inside of any RV, must be kept to an absolute minimum, as stated by the American Gas Association.
Don't even think about it.
Old 11-04-2006, 08:22 PM   #5
1960 24' Tradewind
santa barbara , California
Agree with all posts on this ,no gas lines inside ,they are outside for your
safety and good health .
Scott
scottanlily is offline   Reply With Quote
Old 11-06-2006, 08:40 AM   #6
kamo's Avatar
Ok, thought so. Thanks for the replies.
Grand Hall Ent. gas regulator recall 53flyingcloud LP Gas, Piping, Tanks & Regulators 0 12-23-2002 07:29 AM
Run the fridge while traveling? CBBOB General Motorhome Topics 35 11-26-2002 07:40 AM
LP Gas/Carbon Monoxide Detectors Joseph O. Smith LP Gas, Piping, Tanks & Regulators 28 11-02-2002 01:22 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Small gas gen sets FrankR Electrical - Systems, Generators, Batteries & Solar 0 04-12-2002 02:37 AM
