Old 05-14-2015, 03:33 PM   #1
1964 19' Globetrotter
eagle , Idaho
gas lines attached to bottom skin
are the gas lines supposed to be attached to the bottom of the trailer skin?
mine are but looks like they've been reworked before.
i saw a modern airstream and they were on the exterior of the skin underneath but thought maybe to protect them they should be on the exterior.
thanks,
idahoair is offline   Reply With Quote
Old 05-14-2015, 04:03 PM   #2
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
The gas lines running underneath your trailer should be on the outside of the bellypan skin. If any of those lines have leaks, this allows the gas to escape to the open air rather than accumulating in the spaces between the underside of your trailer's floor and the upper side of the bellypan where it would create a greater fire hazard.
Nomad518 is offline   Reply With Quote
Old 05-15-2015, 03:08 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Propane is heavier than air, you want the lines to to be exposed in case of a leak. They have put them putting on the underside of the belly skins for over 40 years.
Aaron
WBCCI #XXXX AIR #2495
Propane lines on the bottom? Were these original? lakoria LP Gas, Piping, Tanks & Regulators 9 05-07-2014 08:55 PM
How to test gas pressure and bleed gas lines? maggieevans LP Gas, Piping, Tanks & Regulators 12 09-25-2013 06:02 AM
Bathtub leak between top of tub and bottom of shower skin Sunny51 Sinks, Showers & Toilets 2 07-17-2007 08:44 PM
A question on underbelly skin and its gas lines. soldiermedic Belly Pans & Banana Wraps 12 11-23-2006 03:34 PM
How cabinets are attached to the skin 58BUBBLE Cabinets, Counter Tops & Furnishings 3 03-05-2005 10:55 PM
