Old 09-19-2012, 10:04 AM   #1
1970 25' Caravanner
Incline Village , Nevada
Gas line repair at front hitch-help needed
The gas line at the hitch near the tanks on my 1970 Caravanner looks like it was bent back and forth until it broke. I have never owned an Airstream so I was hoping someone could tell me how the line attaches into the regulator assembly... Was there a flex hose or did the gas line feed directly into the regulator?
Thanks.
Jeremy9107 is offline   Reply With Quote
Old 09-19-2012, 10:35 AM   #2
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
The regulator is hooked up to a rubber hose. You should be able to find one at an RV supply.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 09-19-2012, 11:05 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Regulator to trailer tubing
On my 1963 the regulator has a copper tubing line with a spiral wrap in it going to the trailer. This spiral allows some flexibility but over time copper tubing gets cold worked and becomes brittle and may break. When replacing the tubing, new annealed tubing is recommended all the way back to the first tee junction. The connections from the tanks to the regulator are rubber hoses.
